[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
slowsierra
Joined: Sat May 23, 2009 11:30 pm Posts: 415 Location: Greenbank, QLD
Vehicle: 89'SWBsierra&84'LWBsierra
 Posted: Tue Sep 09, 2014 6:54 pm |
Details- 1.3L NT LWB Sierra. Standard brakes around.
problem- so the problem is the brakes where holding on ( on all 4 corners). The pedal would only move a little bit before the brakes would stop the car.
What I have tried- at first I thought it was just the front calipers seized. So I swapped the front brakes to LWB vitara brakes that I knew were in good cond. then I realized the backs were dragging too. So I thought it must be the master cylinder. I swapped it over to another one that I was told was in good cond. but now the brakes are doing something different. The pedal takes a heap of pumps to get pressure and if after you have pressure you remove your foot off the pedal for a second the put your foot on the pedal again it goes to the floor. I have bleed the brakes over and over again and there are no leaks I can see.
What should I be looking for, what else could the problem be?
Blkfxx
Joined: Sat Feb 04, 2012 7:11 pm Posts: 1105 Location: Oberon, NSW
Vehicle: Drover pickup turk
 Posted: Tue Sep 09, 2014 7:37 pm |
Uglitom1
Vehicle: 99 grand vitara 2.0 auto
Did you bench bleed the new master cylinder ?
Uglitom1
 Posted: Tue Sep 09, 2014 7:38 pm |
Blkfxx wrote: Bench bleed M/C and rotate LWB Vit calipers to bleed? viewtopic.php?f=5&t=13747Ha, beat me by 30 seconds mate. Sent from my iPhone using Tapatalk
slowsierra
 Posted: Tue Sep 09, 2014 7:42 pm |
Nope how would I do that? And then I will spin the calipers next time I bleed it.
slowsierra
 Posted: Tue Sep 09, 2014 7:49 pm |
All good just youtubed it
slowsierra
 Posted: Sat Sep 13, 2014 9:57 am |
ok so I have just bench bleed the master cylinder and spun the caliper so the bleed nipple is on top and re bled the rear then the front passengers and last the front drivers. if I put my foot on the brake now the pedal is just about at the floor. I have to pump them to get em to come good. what else can I do?
[ 7 posts ] |
Users browsing this forum: No registered users and 336 guests
