It is currently Tue Aug 11, 2026 5:13 am
Vehicle: 2000 Jimny
Post Posted: Fri Sep 19, 2014 8:51 pm
Sorry not being lazy, just on phone.
Is non coil pack 1997 baleno engine to jimny ok to do, say if use G13b head from jimny with coil packs etc or will it reduce power or not possible? Ask as have come across cheap baleno. Thanks for advice.
Vehicle: LJ50V 2 stroke
Post Posted: Fri Sep 19, 2014 9:34 pm
it'll work.
i've done it before. i used the baleno head, jimny cam and cam cover as well as all the jimny manifolds
Vehicle: 2000 Jimny
Post Posted: Sat Sep 20, 2014 6:30 pm
thanks for that, did you use the jimny coil packs as well ??
Post Posted: Sat Sep 20, 2014 6:31 pm
Jimny and baleno coil packs are the same, but yes, you'd use everything except the short block from the Jimny.
Vehicle: 2000 Jimny
Post Posted: Sat Sep 20, 2014 6:34 pm
here's what i mean about the coil packs being different, i'm guessing this is just a slightly different ignition set up (it's a 1997 baleno, asking $300):
Vehicle: 89 Sierra Widetrack
Post Posted: Thu Sep 25, 2014 3:02 pm
That engine has coil packs.
Vehicle: 2000 Jimny
Post Posted: Thu Sep 25, 2014 4:30 pm
i thought the easier conversion was with the 2 coil packs on the rocker cover as the jimny has ? doesn't matter just now, the car sold in literally 2 days as you'd expect.
Users browsing this forum: No registered users and 82 guests
