Joined: Fri May 15, 2009 11:30 pm Posts: 2108 Location: western vic
Vehicle: sj51
Posted: Tue Sep 23, 2014 7:01 pm
With trip to beachport coming up I was in need of some solo sleeping facilities... add to that im a zook driving tight wad 14 dollar 8x10 tarp 4 dollar gaffer tape will be fitting it out with my exped dm7 mat and which ever bag suits the forcast Fold and tape And again Then double fold the bottom and tape Then flip it over so the double layer is on the bottom
I like the idea - plus the cost is right there with my tight-arse zook budget - but sadly up here in QLD this will end up as a $20 sauna more than a $20 swag. Although the mozzies would probably carry you away and cool you down.
You might get alot of mildew/condensate on the inside of that canvas even if the days are warm.
If I wanted to use a tent I would take my msr hubba hubba I like to ruff it now and then to proove to myself that all this shyte we buy is unnecessary
I used to just lay my bag on the tarp and roll myself up in it like a pig in a blanket, that worked fine, although the leaches at the watto's liked it too
I like this pop up tent more...... simple to set up and cheap too.
Joined: Sat May 19, 2007 11:30 pm Posts: 2535 Location: Perth
Vehicle: 93 Sierra
Posted: Tue Oct 28, 2014 1:30 am
I used to use a tarp as a swag, but you're getting a bit fancy with the tape 'n stuff. Just get one that is big enough to go over + 2 layers under, then turn the end under and shove your shoes down into the corners to hold them put. Works just dandy.
Users browsing this forum: No registered users and 35 guests
