It is currently Sun Nov 01, 2026 3:26 pm
Post Posted: Sat Jun 21, 2014 8:30 pm
Hey AZ,
I thought I would just throw up some pictures and details of this brazier I put together yesterday for anyone interested. It's basically the internal tank of a hot water system, which I got from a mate for free. Some cutting, a little welding and lots of wire wheeling and it was done, I'm happy with the end result considering all materials were free and it only took 3 hours to put together. These things get super hot and are perfect to sit around in winter with a few drinks :beer: .
Start with this big rusty thing. Cut the weld around that center pipe.
Flip it over and cut the weld that holds that end of the tank together.
This thing comes out which later becomes your base.
Cut brazier to desired height.
Plate this hole and then weld the base to the brazier.
Cut out mesh to the ID of the brazier. This sits on top of the lower tapered section of the brazier allowing a nice air pocket to help fuel the fire.
Drill some holes for airflow. Too many holes and the wood burns to fast.
enjoy it :D
Post Posted: Sat Jun 21, 2014 8:42 pm
Neat. 8)
Now do more work on your Sierra! :P
Post Posted: Sun Jun 22, 2014 4:44 pm
:thefinger:
Vehicle: Which one?
Post Posted: Sun Jun 22, 2014 5:17 pm
Great idea. I might pinch this and make one of my own for the farm.
The only "nice" improvement would be to be able to open/close a couple of holes with some sort of swinging flap to get the airflow just right.... but honestly, I doubt I could be arsed. :)
Post Posted: Sun Jun 22, 2014 5:24 pm
old carbie mounted on the base, with the centre pipe stand being used to feed air up to the fire.
big old school 4 barrel, or a couple of webers should look the goods. 8)
stephen
Post Posted: Sun Jun 22, 2014 5:33 pm
I did think about this but I couldn't be bothered spending too much time on it :P , I needed it that night.
You could use an excess piece of the cylinder, cut it and reweld so it slides over the exterior of the brazier. Then drill holes in it at the same spacing as the ones on the brazier so when it's rotated on the brazier it will reduce flow to each air hole.
Vehicle: Which one?
Post Posted: Sun Jun 22, 2014 5:54 pm
stephen
Haha!
Actually, I do have a few 600 vac-sec holley's in the shed doing nothing. Now to crack another beer and work out how to plum some kind of fire-starter into the mix.
Post Posted: Sun Jun 22, 2014 6:30 pm
why not both henno? 8)
Vehicle: Which one?
Post Posted: Sun Jun 22, 2014 6:43 pm
I do actually have pistons and headers a plenty. What a fantastic idea, albeit slightly (very) bogan.
Post Posted: Sun Jun 22, 2014 8:48 pm
a shot of methanol and glow plugs to get it fired up?
or
sparkplugs with magneto on ripcord starter?
stephen
Vehicle: LWB Sierra & XL7
Post Posted: Sun Jun 22, 2014 9:19 pm
Man art.
I think that sold for about $500 didnt it?
'92 Vitara & Camper trailer
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sun Jun 22, 2014 9:59 pm
Always wanted to do one of these, with a turbo and an alternator
Vehicle: suzuki jimny
Post Posted: Mon Jun 23, 2014 8:35 am
:rofl:
hooki wrote:
:thefinger:
Post Posted: Wed Jun 25, 2014 7:54 pm
Have the flue gasses spin the turbo to drive more fresh air in to fuel the fire. Awesomeness.
Post Posted: Wed Jun 25, 2014 8:11 pm
wot like dis?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jun 25, 2014 8:26 pm
tank is a combustion chamber only so it has to have a door that seals really well and a electric motor to spool the turbo to prime it.
combine it with a glowplug and injector for kerro and fill it with wood she would become self sustaining without kerro and turbo-alternating pretty quick.
would be fun to play with (increasing electrical load) to see how much power you could get out of it. turbo size and intake swirl on the exhaust side would prevent some particulate getting into the bearings via Centrifugal force.
solar panel's may be easier, but at night this could heat and light your house. plus you are releasing some CO2 to grow more trees to burn! pompoms
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jun 25, 2014 8:29 pm
wonder if the alternator load got too low if you could melt the thing from producing too much boost. that would be awesome!
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jun 25, 2014 8:34 pm
copper tube direct from the cold side of the turbo into the exhaust tip, and inject extra kerro.
you know, for afterburning.
so visiting the scrap pile at work tomorrow!!!
Post Posted: Thu Jun 26, 2014 9:58 am
THIS I GOTTA SEE .
hope some one builds this thing
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Jun 26, 2014 10:17 am
probably when i move back o gladstone and find a cheep used D11 turbo
Post Posted: Fri Jun 27, 2014 3:57 am
You guys like over complicating things :lol:
Vehicle: Tuff 80, wanna Tuff Zook
Post Posted: Fri Jun 27, 2014 7:13 pm
Now that's kool
Post Posted: Wed Jul 30, 2014 11:41 pm
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jul 30, 2014 11:47 pm
looks like im going quad tubo, with a supercharger
Post Posted: Thu Jul 31, 2014 12:00 am
the snowball effect :lol:
Post Posted: Sun Aug 10, 2014 6:12 pm
Do you even bunsen?
Vehicle: Which one?
Post Posted: Tue Oct 14, 2014 7:38 am
Post Posted: Sun Jan 25, 2015 12:11 pm
RE: turbo .
How do you stop it from seizing up when run at extreme temperatures with no oil lubrication ?
Post Posted: Fri Apr 03, 2015 10:50 am
Here is my fire pit 0.9ton of crusher cone.
Cool one i found on facebook a while ago
Vehicle: MG410 Gypsy
Post Posted: Mon Aug 24, 2015 10:10 am
so much want...
Users browsing this forum: No registered users and 7 guests
