It is currently Wed Aug 12, 2026 4:32 pm
Vehicle: 1984 holden drover (lwb zook)
Post Posted: Sun Oct 19, 2014 9:58 pm
Hey guys i searched and cant find anything
Is there any tutorials on how to swap crown and pinion gears as i have a really good condition wt center and a shit condition nt center but the nt gears are good and want to swap them onto the wt center, if anyone can help link me or pm me on how? Is it hard? Do i need any special tools? Should i replace anything when i do it etc etc
Post Posted: Mon Oct 20, 2014 1:50 am
Yes it is hard. Yes it requires special tools. Take it to a diff shop. I've seen too many sierra and vitara gearsets wrecked by people thinking they are easy to set up.
Vehicle: 85 ' Drover
Post Posted: Mon Oct 20, 2014 7:52 am
Its not so much that its hard, in that it is tedious. And its even more tedious without the correct tools. The main issue is, if you don't get it 100% correct, it will destroy the gears fairly quickly.
My mate and I tried very hard to setup the gears as good as we could in his clubman, followed the manual, and any internet guides we could find. We even used a his uncles mechanic workshop who had reasonable tools. We got it pretty good we thought and it worked well, but it took about 6 months for the gears to get more and more noisy. Ended up taking it to a diff shop after that, and the gears were toast and needed replacement.
It cost me $110 to get the pinion seal replaced in my sierra diff, as well as the gears setup and checked. Well worth it I reckon.
With yours pending condition not a bad idea to replace the carrier bearings while you are there, as well as the pinion bearings. (ie ~$100 just in bearings...) and pending the condition of the gears it might be worthwhile lapping the gears too. costs start to add up, so you don't want it all to come to literal grinding hault by not setting it up properly.
They say the poor man buys twice....unfortunately when it comes to differentials, it can't be more true....
Vehicle: 92 WT Sierra
Post Posted: Mon Oct 20, 2014 4:40 pm
Having only taken the center out, with no previous experience, I can tell you that is daunting enough. Pay someone the money to have it done, mine cost $120 to swap pinon and crown over. Much cheaper and easier then wrecking them and having to start again
Users browsing this forum: No registered users and 60 guests
