It is currently Tue Oct 20, 2026 8:05 am
Vehicle: sj51
Post Posted: Wed Oct 29, 2014 1:22 pm
Problem: Stock wide track flare is to short for vert lift opening
Solution: added 70mm of another flare into the center of it
Post Posted: Wed Oct 29, 2014 8:15 pm
Good job Pezz! Would of been a nice fiddley job
Post Posted: Thu Oct 30, 2014 5:18 pm
Nice. Any pics of the process?
Post Posted: Fri Oct 31, 2014 7:20 am
I've been waiting for the Pezz fab. :)
Nice solution to keeping things looking stock.
SS
Vehicle: sj51
Post Posted: Fri Oct 31, 2014 6:02 pm
Thanks guys,
ive only done the one for far,
will post up some process pic's as I do the other three,
will be sculpting the flares to suit the blinkers and fuel filler also.
Post Posted: Fri Oct 31, 2014 9:48 pm
I like it! Definitely one of the better solutions I've seen. It's so hard to get flares that look ok on sierras.
Vehicle: sj51
Post Posted: Wed Nov 05, 2014 4:51 pm
Front flare done,
60mm extention and cut out to suit blinker
Vehicle: Suzuki Serria
Post Posted: Wed Nov 05, 2014 5:08 pm
pezz wrote:
Front flare done,
Hi Pezz
Any chance of a front on shot ... tyre / flare
Stuart
............. Samsung S4
Vehicle: sj51
Post Posted: Wed Nov 05, 2014 5:57 pm
Will take one tomorrow,
its just a stock width wt flare tho..
Vehicle: LWB Sierra & XL7
Post Posted: Wed Nov 05, 2014 6:35 pm
Nice work, I was going to do this but call me lazy, It's too much work for little gain. I just tilted it towards the front a bit more.
'92 Vitara & Camper trailer
Vehicle: sj51
Post Posted: Wed Nov 05, 2014 7:52 pm
I recon yours looks neater, with the front endge all the way down and not sitting as high
Post Posted: Wed Nov 05, 2014 8:41 pm
Yours is very seamless and you've done a good job of it, i just took the easier option.
Vehicle: sj51
Post Posted: Thu Nov 06, 2014 8:41 am
flares are yet to be bolted on, they are just stilling on the mounts,
still need to make up some inner trims to fill the void between the flare and the body
Tyre position will change as I've yet to bolt up my wt diffs,
currently 15x8 rim with neg offset, but will be going to a narrower rim with possitive offset to keep it skinny
Users browsing this forum: No registered users and 20 guests
