It is currently Sat Oct 24, 2026 9:16 pm
Vehicle: 1996 Suzuki Sierra SJ70
Post Posted: Tue Nov 04, 2014 10:32 pm
The Carby is intermittently starving for fuel and is leaking from the plunger. It is a 1996 SJ70, what could some of the issues be? We only had it rebuilt 2 years ago, it's stock.
Post Posted: Wed Nov 05, 2014 6:38 am
The plunger leak is only minute. The starving for fuel happens sometimes when you put your foot down.
Vehicle: 85 ' Drover
Post Posted: Wed Nov 05, 2014 7:44 am
You had the carby rebuilt? or the engine.
If its leaking, Best off not to muck around, buy a carby kit, like $55 from repco. Put that in, clean everything while you are there, and make sure the float height is correct.
Carby kit will include a new plunger.
Post Posted: Wed Nov 05, 2014 5:33 pm
Thanks for recommendation. We had Carby rebuilt.
Vehicle: 93 Sierra
Post Posted: Wed Nov 05, 2014 5:55 pm
Re the starving for fuel, there's a stainless steel filter mesh inside the carby where the fuel line slips onto it. Try pulling that out and checking it for blockages. I had a heap of junk in mine at one point (not long after a rebuild) that meant it would starve under load but would idle quite happily. Also consider putting an extra fuel filter between the fuel pump and the carby to provide a bit of extra protection against muck in the fuel lines.
Post Posted: Wed Nov 05, 2014 6:10 pm
How old is the fuel pump?
Post Posted: Wed Nov 05, 2014 7:01 pm
Just took it into the Carby shop and discovered the problem is electrical.....back to drawing board. Intermittent surging. The revs cut out.
Post Posted: Wed Nov 05, 2014 8:15 pm
What about the leaking plunger? Which I assume is the accelerator pump.
Post Posted: Thu Nov 06, 2014 4:47 pm
You can see residue around the plunger at the front right of the Carby but it wasn't leaking when tested and you can't see moisture there so I don't know what's happening have booked it in to get analysed next week.
Users browsing this forum: Google [Bot] and 181 guests
