It is currently Fri Nov 13, 2026 6:57 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 19 posts ]
Post Posted: Thu Oct 23, 2014 1:44 pm
Top
I know its been some time since I've been online, unfortunately I've been in and out of hospital, but my loss is someone here's gain, I'm asking $1000 ono for my 1990 vitara, has a rebuilt motor with a G16B block, has been parked in the shed unregistered so battery is dead but drove it in the shed, but rear diff was starting to show a bit of noise, there is the whole set of 4.6 diffs that can go with it, the bucket seats go with it also, never used, the webber carb with rebuild kit and adapter plate, the LH window reg has failed, there is a second hand one ready to fit, has a bikini top purchased through here, door trims are covered with a red checker plate plastic, has sports steering wheel fitted (orig is there to go with it) rear tyres and spare tyre are almost new, 235/75R15s, the front tyres are getting low on tread 30x9.5r15s, has rear, all are on large offset rims, has front and rear spotlights that are run through the appropriate high-beam/reverse switch, also has body-lift and raised springs I believe, has a tube front bar.
forgot to mention has LWB front brakes also
See attached photos to see everything:
yes has been sitting about for a while, but I believe the asking of $1000 is a exceptional deal for everything there
Post Posted: Sun Oct 26, 2014 1:37 pm
Top
Pm sent
Post Posted: Thu Nov 06, 2014 3:24 pm
Top
Vitara sold, couple of bits remain:
2x Bucket seats (unused) $150 ono
4.6 Diffs F&R (front pinion nut has been removed, but ran smoothly, rear is drum-drum) Make an offer (SOLD!)
Vehicle: Suzuki sierra jx
Post Posted: Wed Nov 12, 2014 7:22 am
Top
Would yo sell the weber seperately if so what type is it
Post Posted: Thu Nov 13, 2014 3:09 pm
Top
sorry, the weber sold with the vitara, all that is left is the bucket seats
Vehicle: 1984 holden drover (lwb zook)
Post Posted: Fri Nov 14, 2014 9:05 am
Top
would you post the bucket seats?
Post Posted: Fri Nov 14, 2014 10:16 am
Top
at your expense, im unsure how much that would be, pretty bulky
Vehicle: 2000 Jimny
Post Posted: Fri Nov 14, 2014 11:04 am
Top
if bibby doesn't grab the seats i'd be interested, but he got in first so see if he's keen.
Post Posted: Sun Nov 16, 2014 12:46 pm
Top
Bit more info on the seats
Seat measurements:
Bolt holes
side to side 345mm
Front to back 270mm
Whole base
Side to side 500mm (including recliner mech)
Front to back 520mm
Widest point (shoulder bolster) 530mm
Vehicle: 2000 Jimny
Post Posted: Sun Nov 16, 2014 1:35 pm
Top
if any one knows how to overcome the issue of using the jimny rails including seat belt clip i'd be keen to hear. i was hoping to use these seats but i think the most i could fit is about 480mm with the seat belt clip still on:
Post Posted: Tue Dec 02, 2014 6:21 pm
Top
Seats still available
Post Posted: Thu Dec 04, 2014 4:51 pm
Top
I might be interested in those seats. I'll measure up the swift when I get home tonight...
Post Posted: Fri Dec 05, 2014 7:36 am
Top
sure thing mate
Vehicle: 1992 Sierra Soft top
Post Posted: Sat Dec 06, 2014 10:26 pm
Top
hi mate still got the seats ? if so can you post some pictures or pm mob # and ill txt you cheers
Vehicle: 1993 Suzuki Vitara JX
Post Posted: Thu Dec 11, 2014 5:21 pm
Top
I'll take the Seats if they're still available and will deff fit a LWB vit?
Post Posted: Fri Dec 12, 2014 7:47 am
Top
you need to sort out the rails for them, there used to be someone that made an adapter but I've been out of the loop for a bit, but they are still available
Post Posted: Sun Dec 28, 2014 2:24 pm
Top
If anyone wants to take these seats before Jan 1, I'll accept $100, remember these have never been used, grab a killer deal
Post Posted: Sun Dec 28, 2014 9:55 pm
Top
Hey mate. I lent my swift out to someone before I could measure the bolt holes. I'll grab the seats anyway and figure out fitting them later. PM me your address, will you be home tomorrow?
Post Posted: Mon Dec 29, 2014 3:11 pm
Top
All sold - Thanks all
Users browsing this forum: Google Adsense [Bot] and 16 guests
