It is currently Tue Oct 06, 2026 11:59 am
Post Posted: Wed Sep 09, 2009 1:48 am
was just wondering whats the largest size tire i can fit on a standard rim. looking at 30x9.5x15 i dont htink they will fit.
just dont no if ill have money for rims
thanks
Post Posted: Wed Sep 09, 2009 1:56 am
30's wil fit but not ideal. I've even seen a 31 fitted to a standard rim 8O
Post Posted: Wed Sep 09, 2009 1:58 am
OK that would be good, the tires i wont are 30x9.5x15 so if i can get them on it would save me some hassle for a while until i can get rims maybe a month or 2 later.
Post Posted: Wed Sep 09, 2009 2:01 am
my mate runs some 30x9.5's on his stock rims
they fit fine they just don't get pushed out as much as if they were on wider rims if you know what i mean
but they'll still work- would probably just have to watch pressure to make sure they wear evenly
My Rig --> Click WWW
Post Posted: Wed Sep 09, 2009 2:20 am
a 30 isn't anywhere near the largest tyre you can run on a stock suzuki rim.
34 9.5 15 Swamper will go on a standard sierra rim.
A 9/34 16 Swamper will go on a 16" sierra/LJ rim
A Q 78 swamper will go on a 16X7" XL-7 or GV rim. That's 35.5 tall.
a 9.00 16 will go on a 7 rim easy, that's 36" tall.
Pretty sure you could run a 38X11 16 bogger on a GV rim too. :D
However, these are all cross ply tyres so aren't as rim width sensitive
A 30 X 9,5 isn't ideal on a sierra rim, but it's OK short term. It will likely crown a bit and the handling on road won't be as good as it could be. You will also have tyre clearance problems on the shock mount/inner guards unless you are WT.
Post Posted: Wed Sep 09, 2009 12:00 pm
ok thanks steve bid help i wont have them on there for too long. :)
Users browsing this forum: Google Adsense [Bot] and 106 guests
