It is currently Fri Nov 13, 2026 1:09 pm
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Thu Sep 05, 2013 3:48 pm
SierraDan wrote:
What do people do with the passenger side radiator mount now that the drivers side is spaced across?
Mine had enough room to stay where it was, I just redrilled mounting holes in radiator sides.
Mine was a 1.0 LWB with a 1.3 etc fitted.
Post Posted: Thu Sep 05, 2013 3:53 pm
i just welded a dog leg into the upright and spaced the bolts 25mm
Post Posted: Thu Sep 05, 2013 4:10 pm
Cool, so there isnt any obvious bolt in way. I'll go ahead with weld shit to shit.
What about the fan?
Post Posted: Thu Sep 05, 2013 4:13 pm
not sure i didnt use one
Post Posted: Thu Sep 05, 2013 4:18 pm
I'm assuming you have a BenT kit? the radiator is spaced over 20mm with a small piece of SHS, redrill the holes in the flange on the radiator 20mm closer to the core. My fan and shroud still fitted fine after i notched it, I have a vit clutch fan. The holes in the shroud are slightly slotted so you can push it all the way over to the drivers side and tweak it a little as you tighten up the bolts that hold it to the radiator.
Edited: pics and better description
Trimmed Shroud
Re-Drilled flange
Spacer
Passenger side all still stock
Post Posted: Thu Sep 05, 2013 4:22 pm
Ah rightio. Well i have a Vit clutch fan too, just need to buy bolts tonight.
I'll give that a go tomorrow. Cheers.
Post Posted: Fri Sep 06, 2013 12:17 pm
Worked a treat!
Post Posted: Fri Sep 06, 2013 12:52 pm
Nice! You'll notice a vit fan makes a noticeable difference on te temp gauge too.
Post Posted: Fri Sep 06, 2013 3:24 pm
In drop?
It seemed to warm up quicker which was good.
Post Posted: Fri Sep 06, 2013 7:37 pm
Pretty sure mine gets to temp quicker too. Doesn't get as hot when driven hard and under normal conditions its a little lower as well. I reckon its an awesome bolt on upgrade.
Vehicle: Drover pickup turk
Post Posted: Sat Nov 16, 2013 2:19 pm
Anyone else come across this issue? G13a and Vit power steer. Should I notch the bracket or take the little bit off the exhaust manifold?
I like the tuna here
Post Posted: Sat Nov 16, 2013 2:33 pm
Stock manifold Blkfxx? Looks like the tab that's hitting the bracket is the one that holds the heat shield on. You'd be OK to trim that if you don't intend putting the heat shield back on.
Post Posted: Sat Nov 16, 2013 2:56 pm
Yea stock manifold, The heat shield wasn't on it when I bought the car so no worries about that ever finding its way back on there.
Thanks Damo!
Post Posted: Sun Nov 17, 2013 5:50 pm
Another question. Where does everyone mount the reservoir?
I remember seeing this pic from Damo's thread, But the return hose/pipe points straight at the overflow bottle and there doesn't seem to be enough room once a hose is on there.
Vehicle: 4wd
Post Posted: Mon Nov 18, 2013 2:55 pm
Here is an option.
Watch out or you'll get sued.
Vehicle: '94 suzuki maruti
Post Posted: Wed Jan 08, 2014 7:25 pm
Has anyone else done the power steer install with the JML front bar? I cant fit the steering box because its hitting the top bolt of the bracket, looks like i'm going to have to remove the top bolt for the bracket as well as grind it a little, and just run the 2 bolts on that side...
Vehicle: 92 tintop sierra
Post Posted: Wed Jan 08, 2014 8:46 pm
Post Posted: Wed Jan 08, 2014 9:45 pm
thats my issue exactly... bugger.
Post Posted: Wed Jan 08, 2014 10:34 pm
Just grind it away till there is clearance. Do same with the bolt head.
Post Posted: Thu Jan 09, 2014 4:42 pm
got the box in with some grinding, same with the pump (had to notch part of the headers)... next (very n00b) question: is this a collapsible steering column? Thought I'd read the WT maruti has the collapsible type but this wont fit... and i wouldnt have a clue how to tell the difference.
Post Posted: Thu Jan 09, 2014 5:01 pm
Yep that's a collapsible, There will be 2 plastic pins holding it where it's at, See if you can find them (may have to sand some paint back) and knock them out. Then simply adjust to fit.
Post Posted: Sun Apr 13, 2014 6:20 pm
Does anyone know what size the banjo bolt is on the pump? (Vitara pump)
Vehicle: suzuki, jimny 1998
Post Posted: Sat May 24, 2014 5:53 pm
Can you get the power steering and ac adapter plates separately? Can you post a link to the site you got ti from
Post Posted: Thu Jan 15, 2015 11:33 am
Anyone have this issue?
It's viscous fan (Jimny or Vit, Not sure which) with the radiator support spaced over for the Vit power steering box. Baleno G16B with VL mounts.
Post Posted: Thu Jan 15, 2015 1:12 pm
No, I don't think I did. My fan is off a Vitara.
Post Posted: Thu Jan 15, 2015 1:32 pm
Some of the g13bb jimnys have the same fans as vits, some are different.
Whats the driver side engine mount like? Has it cocked the engine over a little?
Post Posted: Thu Jan 15, 2015 2:56 pm
I didn't think to look at engine mounts but now you mention it, Looks like the motor is pushing forward.
I'm trying to upload pics but photobucket isn't playing ball.
EDIT:
Post Posted: Thu Jan 15, 2015 9:00 pm
Pics of your fan? Did you put the sierra alloy spacer in there?
Post Posted: Thu Jan 15, 2015 11:45 pm
No alloy spacer
Vehicle: Suzuki Sierra Sj70
Post Posted: Thu Mar 15, 2018 4:54 am
Hello can Blkfxx and Jono165 please send me your pictures from photo bucket
As im just seeing the "unlock photo bucket" image
Users browsing this forum: No registered users and 58 guests
