It is currently Sun Nov 15, 2026 10:11 am
Post new topic Reply to topic  [ 251 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9  Next
Vehicle: 89 Sierra Widetrack
Post Posted: Tue Nov 12, 2013 6:32 am
Forget which ones I used but easy to get off and would be a good spare.
Vehicle: Soon to be Sierra (hopefully)
Post Posted: Wed Nov 13, 2013 9:31 pm
Trying to organise it all and the links dont work anymore... so its hard to tell
VL motor mounts (is it these ones?)
http://www.ebay.com.au/itm/Holden-VL-6c ... d2b&_uhb=1
clutch kit? is this the right one (exedy hd)
http://www.ebay.com.au/itm/H-DUTY-CLUTC ... 256b0938d0
swift 1.3L thermostat housing
http://www.suzistore.com.au/onlinestore ... etail.html
which thermostat?
swift 1.3L?
Baleno 1.6L?
Sierra 1.3L?
surely its the baleno thermo or doesn't it fit in the housing right?
timing belt kit (major 100k service)
http://www.ebay.com.au/itm/TIMING-BELT- ... 68a&_uhb=1 (on sale for the next 3 days)
Vehicle: SJ51T
Post Posted: Thu Nov 28, 2013 6:34 pm
I grafted my baleno temp gauge into the sierra dash and kept it all the same at the dash end.
Just stopped workin yesterday damn it!
Vehicle: 15 LJ50's, 5 LJ20's, 3 sierras
Post Posted: Sun Aug 17, 2014 1:38 pm
Hey guys, sorry if I'm asking questions that have already been posted on this thread but I am currently putting a 1.6 baleno motor in one of my sierras, having a few issues with working out how much of the sierra sump needs to be cut for the crank angle sensor and also the wiring loom, I did read here a while ago that there is a place where I can send it to be changed?
Vehicle: 92 wt soft top sierra
Post Posted: Fri Aug 29, 2014 10:10 pm
Killa kustom kables is your man for the wiring loom he does quite a good job
Vehicle: Drover pickup turk
Post Posted: Sun Jan 04, 2015 5:10 pm
FWIW, Super cheap auto online (through the parts guide) do a pair of VL engine mounts for $37.74 with free postage.
I like the tuna here
Vehicle: Daisy
Post Posted: Thu Jan 29, 2015 10:59 pm
I think I put up some pictures in my build thread of doing the sump, it's probably not the best way and it's not been tested with the motor running yet but it bolted up spot on. Search my post history for a thread titled daisy and you will find it!
Vehicle: Suzuki Sierra
Post Posted: Thu Feb 19, 2015 9:13 pm
Hey do you have to change the fuel tank from the stock 1.3 one?
Post Posted: Thu Feb 19, 2015 10:09 pm
Yes unless it's a coily or you use a surge tank and extra pumps.
Post Posted: Fri Feb 20, 2015 8:42 am
so, coily tank.. what other tank vit tank?
Post Posted: Fri Feb 20, 2015 9:15 am
What car is it going in?
Coily tank bolts into SWB, LWB soft top and Maurtis' or with custom mounts the 40L SWB EFI Vitara tank can be fitted.
For traybacks (maurtis' excluded) you can fit the 55L LWB Vitara or the 80L EFI Holden Jackaroo tanks with custom mounts (There are a couple of threads with pics floating around)
Coily tanks are the same as 1.3 leafy tanks except they have a swirl pot and can be fitted with an EFI pump/pickup assembly from a vitara or baleno
Post Posted: Fri Feb 20, 2015 9:23 am
cheers
Vehicle: G16b Sj80, Version 6 GC8 STi
Post Posted: Wed Mar 23, 2016 12:43 pm
Thanks so much for this thread Cairnszook, it's been really helpful!
Cab anyone tell me what these are though? Not sure where they go or what they do.
Also what's this big hole for? Image
Subi + Suzi = Best of both worlds!
Vehicle: 2000 Jimny
Post Posted: Wed Mar 23, 2016 2:11 pm
those 2 hoses are vacuum hoses & reconnect to your inlet manifold (if no one gives a better explanation please bump this & i'll take photos of mine so you can see where they go).
that other big hole i'm pretty sure is left as is (as before though bump & i'll take photos tonight to make sure).
Vehicle: 98 sierra coily
Post Posted: Wed Mar 23, 2016 4:36 pm
That one in your right hand goes to the hole just at the end of your fingers. You are missing a part it connects too.
I think the other one goes to the fuel Evap canister??
Post Posted: Wed Mar 23, 2016 4:38 pm
Sorry won't let me upload pics anymore. There should be a red thing in that hole right unde the hose.
And yeah. Don't worry about that second hole.
Post Posted: Thu Mar 24, 2016 12:49 pm
What is the red thing that I'm missing from the hole?
Post Posted: Thu Mar 24, 2016 6:52 pm
Sorry I don't know. I went out and took a photo of mine. However I googled and there is a pic on a manifold in this thread with it on. Have a scroll I can't post pic.
Post Posted: Wed Mar 30, 2016 6:05 pm
Re the temp sender issue
There is a location where a temp sender can be installed on the thermostat housing. If you look closely, you will see it near the baleno temp sender
I ran a 8.8mm drill bit through the little spot and tapped it to suit the sierra temp sender.
Post Posted: Sun May 10, 2020 8:50 am
I’ll be doing this conversion again soon but I’ll be using the G13bb jimny inlet manifold instead
 Profile YIM
Post Posted: Sun May 10, 2020 9:28 am
I would strongly recommend retaining the Baleno water neck on the back of the block.
Post Posted: Sun May 10, 2020 2:16 pm
Can you explain why?
Sent from my SM-A530F using Tapatalk
Post Posted: Sun May 10, 2020 2:56 pm
Yes, I've mentioned this a few times.
Vitaras have a reputation for cracking G16B heads and doing head gaskets.
Vitara G16B's in Sierras seem to crack heads and do head gaskets, regularly, or at least have that reputation
G16B's swapped into Jimny's do heads/head gasket.
Balenos do not have this reputation.
My theory is it's due to coolant flow.
Baleno's put the whole coolant flow through the block from end to end. In at the water pump, out at the back of the block.
Vitaras and Jimny's dead head the back of the block, coolant has to return back through the head to the thermostat housing. The heater hose is attached to to the back of the head and in a vitara the heater core has full flow at all times. I haven't checked the way the heater works in a Jimny.
Sierra's heater core only flows when the heater is engaged - it's a simple tap.
I have checked this with factory service manual coolant flow diagrams.
I don't think that there is a coincidence between coolant flow and head cracks- and the worst case being people (like me) who used to swap G16's into sierras and hook the heater up as per a Sierra.
Post Posted: Thu May 14, 2020 10:33 pm
O.k... thanks.
So.. if im already using g13bb manifold on the g16bb... how would you suggest for me to change the samurai heater tap?
Post Posted: Thu May 14, 2020 10:49 pm
Use a bypass tap so there’s full flow out of the back of the block. It’s the best you can do.
Post Posted: Sun May 17, 2020 1:46 am
Thanks steve.. any sugesstion for a specific one?
Post Posted: Sun May 17, 2020 9:59 am
No, I haven't played with them. I recall someone mentioning a vehicle model with a bypass tap the other day but can't recall what it was, sorry.
Post Posted: Sun May 17, 2020 11:24 am
There’s a thread a while back. The one I plan to try is HQ Kingswood and others around that era. I’m sure there’s a billion others you could try too.
https://www.onlineautoparts.com.au/prod ... /ZPN-01366
Post Posted: Sun May 17, 2020 5:15 pm
Thank you guys! Appricated.
Users browsing this forum: No registered users and 93 guests
