It is currently Thu Jul 23, 2026 12:26 am
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
Vehicle: 1984 holden drover (lwb zook)
Post Posted: Thu Feb 26, 2015 8:23 pm
hey guys,
i did the falcon 110 amp alternator swap and also upgraded all my charging wire and negatives cables with 2 guage cable to help prevent voltage drop and now when the car is on its reading 15 volts of charge is this bad or good?
is it over charging?
any response would be great thanks
Sam
Vehicle: Drover pickup turk
Post Posted: Thu Feb 26, 2015 8:27 pm
Did you hook up a relay on the sense wire like that diagram I sent?
I like the tuna here
Post Posted: Thu Feb 26, 2015 8:29 pm
yup sure did
Post Posted: Thu Feb 26, 2015 8:30 pm
why would that effect it anyways?
Post Posted: Thu Feb 26, 2015 8:37 pm
The original sense wire is quite long, so voltage drop is inevitable (which causes the alt to output a higher voltage) The relay bypasses it.
Vehicle: XL-7 (gone) + Kizashi
Post Posted: Thu Feb 26, 2015 8:51 pm
A sense wire should have next to no current being drawn through it - so negligible voltage drop. (That's the whole idea of using a separate wire for sensing the voltage.)
Post Posted: Thu Feb 26, 2015 9:00 pm
It has sorted mine and everyone elses that has had a high charge voltage. Weird.
Post Posted: Thu Feb 26, 2015 9:17 pm
so is it okay or not?
Post Posted: Thu Feb 26, 2015 9:34 pm
15v is too high IMO.
Mines charges no higher than 14.5v
Post Posted: Thu Feb 26, 2015 9:44 pm
what could it be do you think?
Post Posted: Thu Feb 26, 2015 9:47 pm
Yes, that's strange.
Have the engine to chassis and battery to chassis earths been cleaned up/ checked/ replaced. Perhaps you're developing a voltage drop over those connections?
Also, where is the voltage sense wire hooked up to?
Perhaps try checking the voltage from the alternator's body (use that as your earth) to the sense wire terminal - see what voltage reading that gives you.
Post Posted: Thu Feb 26, 2015 10:36 pm
yes as stated all earths and charging cable was replaced with 2 guage to stop voltage drop, also the volt guage is hooked up to the battery and an ignition 12v as it is suppose to. i also tried with a multimetre on the battery and same reading?
its a optima d34 battery just so you know aswell
Post Posted: Thu Feb 26, 2015 10:41 pm
Try measuring between the alternator's metal body and the sense wire terminal on the alternator - see what voltage you get.
Post Posted: Thu Feb 26, 2015 11:00 pm
why do you think i may just be getting an incorrect reading?
Post Posted: Thu Feb 26, 2015 11:02 pm
and thats the bottom pin when installed correct?
Post Posted: Fri Feb 27, 2015 9:12 am
Measuring at that point will be as close as you can get to reading the exact voltage the regulator is sensing. It bypasses all your wiring loom (ie. external voltage drops) and will give a better idea on what the regulator is really seeing.
Post Posted: Fri Feb 27, 2015 9:16 am
and what should that be? 13.6-14.8?
Post Posted: Fri Feb 27, 2015 10:15 am
Yes, that's probably a good ballpark figure (high 13v to low 14v range.)
Post Posted: Fri Feb 27, 2015 10:32 am
no worries ill be at the shed tomorrow ill test it, what do i do if that reads good?
Post Posted: Fri Feb 27, 2015 11:09 am
There's most likely a voltage drop where you are picking up your 12V from, thus causing overcharging. Measure the sense voltage at the alternator as Murcod suggested and you will probably find that it will be a volt or so lower than at the battery terminal. In this case, add a bypass relay like Blkfxx suggested
Vehicle: SJ80, SE416
Post Posted: Fri Feb 27, 2015 12:49 pm
The 'sensing' wire to the alternator is fed from the same circuit as the ignition coil and meter cluster, through the same fuse and ignition switch contact. There is a few amps being drawn there, and I'm not entirely sure how the regulator is wired but I thought the field current was sourced from that terminal also.
Post Posted: Fri Feb 27, 2015 1:30 pm
i have a relay in the system like this but ill do the test on the alternator and if its correct ill check the connections on the relay
Post Posted: Fri Feb 27, 2015 1:49 pm
The above diagram has the pin numbers correct but the connection inside the relay is drawn wrongly.
Also don't forget to fuse the wire between the battery and relay.
Post Posted: Fri Feb 27, 2015 2:38 pm
:oops:
I drew it pretty quickly, That's my excuse and I'm sticking to it :lol:
Post Posted: Fri Feb 27, 2015 4:35 pm
15v is way to high u will boil the battery.
Post Posted: Fri Feb 27, 2015 9:14 pm
Perhaps (if the voltage measured directly at the alternator is within spec) all that will be required is to run a new sense wire to the battery positive terminal.
(.... and perhaps check for voltage drops across the earths from the alternator body to the battery negative terminal.)
Post Posted: Sat Feb 28, 2015 2:35 pm
15 amp fuse from the battery to the relay?
and okay guys ill give it a check this arvo
Post Posted: Sun Mar 01, 2015 8:20 pm
Sometimes when the built in voltage regulator fails the alt will put out 15+ Volts.
Post Posted: Tue Mar 03, 2015 3:05 pm
its a brand new alternator still haven't checked it but ill check it today i think it was doing it as my sensor wire was going to the fuse on the charging cable instead of the positive terminal would that cause a difference? ill check it when i get home today
Post Posted: Thu Mar 05, 2015 10:21 pm
yeah dosent seam to be working must of been manufactured with a faulty regulator so now i gota try and get warranty which i cant see happening urgh
Users browsing this forum: No registered users and 72 guests
