| Author |
Message |
jonno_racing
Joined: Wed Apr 15, 2009 11:30 pm Posts: 8164 Location: Tassie
 Posted: Tue Feb 03, 2015 7:44 am |
So a idea to get the ute happier on big angles, looking at a bike carbi. 250cc Chinese carb can be bought very cheap, and a small adaptor will see it on. Potential issues would come from running to lean, setting up throttle cable, and they have a vent out as well? The inlet is the same size as the stock carb. Any ideas or thoughts on this? Could be setup for about $30-$50, a worth while investment, could also keep a spare one in glove box for that kind of $$
_________________ Do cool stuff, Put it on the internet Sierra build, Jimny build https://www.youtube.com/user/redzook1
jonno_racing
 Posted: Tue Feb 03, 2015 7:57 am |
jonno_racing
 Posted: Wed Feb 04, 2015 5:57 pm |
Marko_SJ
Joined: Tue Jan 17, 2012 1:40 am Posts: 2979 Location: Darwin, NT
Vehicle: WT sierra, GU CRD
 Posted: Wed Feb 04, 2015 6:06 pm |
jonno_racing wrote: No one has experience with them? I don't - but I'd be looking at what kind of jets it uses when you (will) need to re jet. The way you have worded your original post suggests that you are thinking of using one carb (apologies if I'm wrong) It also looks like an older round slide carb. If I recall correctly (I wanted to do bike carbs at one point) People use carbs to suit around 600cc bikes (edit: this was G13s!). Most bike carb setups use one carb for each cylinder and thats how I'd run it. If I were you, I'd buy a wrecked sports bike of a name brand for as cheap as possible (make sure its an inline four) strip and rebuild the good quality Mikuni or Keihin carbs, and part the rest to make back some money. Hope your project goes well.
_________________ I love ZD30. :)
Marko_SJ
 Posted: Wed Feb 04, 2015 6:12 pm |
Oh, and motorbike carbs are waaaaay more fun to work in.
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Wed Feb 04, 2015 6:14 pm |
I found the 1ltr sidedraught carby great on angles much better than the 1.3 carb. U can get them brand new on ebay for $120ish
jonno_racing
 Posted: Wed Feb 04, 2015 6:56 pm |
Nope single carb. I have bought one. Quad carbs are a head fuck from talking to people who have set them up. Maby I expect to much but on big leans buy previously it has sucked for me. Time will tell.. I might try run similar jet size as the stock f10a carb?
jamiec
Joined: Fri Jan 20, 2012 8:28 pm Posts: 52 Location: West Coast Tasmania
 Posted: Wed Feb 04, 2015 7:12 pm |
1 carb will be fine on a four cylinder four stroke as only one cylinder will be drawing on the carb at any time. Let us know how it works out. I have been thinking of running an SU carb on my LJ80.
MrRocky
 Posted: Wed Feb 04, 2015 7:16 pm |
Ive rolled with a 1ltr carb doing alot of crawling and found tgem great but all have been maruti with under 100xxx on the clock. Perhaps just try a new one first its only $120. Lots of people have a go at rebuilding carbs themself and fail miserably
jonno_racing
 Posted: Wed Feb 04, 2015 7:21 pm |
The mg410 carb has some vacuum gear on it that id like to avoid. The carb I have bought is off the bigger Chinese bikes. The issue with su carbs is there all old, expensive and well used. I will let you know how I go. There is plenty "how to tune" sights online.
Marko_SJ
 Posted: Wed Feb 04, 2015 7:27 pm |
jonno_racing wrote: Nope single carb. I have bought one. Quad carbs are a head fuck from talking to people who have set them up. Maby I expect to much but on big leans buy previously it has sucked for me. Time will tell.. I might try run similar jet size as the stock f10a carb? Yeah, thats why I left it in the "that sounds kinda cool" category. I thought you may have been wanting to do the typical "better on angles more power and looks + sounds cool" setup like everyone else. Like me  . Bike carbs are good on angles from my experience crashing bikes. So long as you aren't upside down or on your side you'll be fine. If it were me I'd use a jet similar size to what you have to start with.
jonno_racing
 Posted: Sat Feb 28, 2015 5:42 pm |
So.. this carbi arrived quite a while ago and i had put it in the to hard basket.. last night a mate pulled the carbi down and had a look at it.. these carbi's are SO simple.. so today we made it work the adapter was fairly easy to set up, some tapered bolts and i had to turn some bolts into studs and weld them to the other side.. then we fitted it up, and decided to see what would happen.. and it started! straight off the bat, ran smooth and idled.. we then made up a throttle cable, and well it wouldn't rev.. some tinkering and we pulled the fuel jet out (it only has one fuel jet and one for idle.) and ran a 1.5mm drill bit though it... we then had it running and had to adjust the needle to about the middle... and wow.. it has a good 10% more power, perfect throttle response!! the carbi works completely different than the stock one, it also has a deeper bowl and the jets are much further down into the fuel! so it should realistically run on a bigger angle!  don't mind the ugly adapter  i still need to fix up the hose to the air box and make up a more perminiant cable cover.  But yes it does work! and works well!
damagera
Vehicle: 1991 swb vitara JLX
 Posted: Sun Mar 01, 2015 9:19 am |
is the acid for cleaning OR drinking
narrowzooker
Joined: Thu Jan 23, 2014 9:00 pm Posts: 320 Location: ARMADALE
Vehicle: 85 holden drover
 Posted: Sun Mar 01, 2015 12:17 pm |
I'm having my quad carby set up for a f10a made up as we speak
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5943 Location: Northcliffe, W.A.
 Posted: Sun Mar 01, 2015 1:37 pm |
For what it's worth, an SU (HS4 is good but HS6 and HS8 will go on too) will bolt onto an F10a manifold with some filing. They're good on angles and are very simple/tuneable. They're also actually larger than the standard carby.  Pics or GTFO denby.
atari4x4
 Posted: Sun Mar 01, 2015 3:28 pm |
damagera wrote: is the acid for cleaning OR drinking acid is for ingesting.
narrowzooker
 Posted: Sun Mar 01, 2015 8:00 pm |
Haha you gtfo hayden there being made in Queens I'm in Perth so I have no pics
jonno_racing
 Posted: Tue Mar 03, 2015 6:45 pm |
Acid is for cleaning your insides, detox is for pussys Well I have been playing a little with the ute, new throttle cable, a touch longer than stock, that allowed it to fit with no kink or need for a bend in it!! The stock choke cable fitted up like it was made for it and the stock intake hose was 5mm to big, so I made up a little sleave from a pit bike air cleaner and a dot of super glue holds it inside the stock hose before the hose clamp does its thing. Issue I have atm is these carbi's rely on the vacuum in them, its what sets the tune basically, however the snorkel was adding a fair bit of resistance. So that will need a upgrade of some kind! I will grab another ebay carbi before my bucks just in case.
scottiej
Joined: Thu Nov 11, 2010 11:53 am Posts: 50 Location: UK
 Posted: Wed Mar 04, 2015 10:15 pm |
sideways wrote: For what it's worth, an SU (HS4 is good but HS6 and HS8 will go on too) will bolt onto an F10a manifold with some filing. They're good on angles and are very simple/tuneable. They're also actually larger than the standard carby.  Pics or GTFO denby. The HIF38 is the chosen SU for the F10a in the UK, a brilliant little carb and they seem to cope better at angles that the HS series carbs. You can get full rebuild kits for them and even buy them new, they are such simple carbs to rebuild it's often not hard to revive them. http://sucarb.co.uk/Sounds like the single bike carb is working well!
JrZook
 Posted: Thu Mar 05, 2015 10:16 am |
jonno_racing wrote: Issue I have atm is these carbi's rely on the vacuum in them, its what sets the tune basically, however the snorkel was adding a fair bit of resistance. So that will need a upgrade of some kind!
All carbies rely on vaccum to function. Some are more finicky than others. So yea if it runs well without the snorkel then you know you have a large restriction somewhere.
jonno_racing
 Posted: Thu Mar 05, 2015 1:11 pm |
JrZook wrote: jonno_racing wrote: Issue I have atm is these carbi's rely on the vacuum in them, its what sets the tune basically, however the snorkel was adding a fair bit of resistance. So that will need a upgrade of some kind!
All carbies rely on vaccum to function. Some are more finicky than others. So yea if it runs well without the snorkel then you know you have a large restriction somewhere. Yeah 100% agree. For all I know something may even be in the pipe! I will build a new snorkel when my life settles down. I also bought a full overhaul lit from ebay $16 delivered. So a spare set of seals and a float etc. I will order a genuine mikuni at some stage there under $100 delivered.
JrZook
 Posted: Thu Mar 05, 2015 10:02 pm |
Got a link to the actual carb you have? I've been playing around with quite a few bike/outboard carbs over the past year
jonno_racing
 Posted: Fri Mar 06, 2015 6:35 pm |
qwerty123
Joined: Thu Mar 31, 2011 10:05 am Posts: 33 Location: Pakenham
Vehicle: Coily
 Posted: Fri Mar 06, 2015 8:32 pm |
This is great,
These are the easiest carbys to play with. for $27 you cant go wrong
good luck getting it jetted/running right, for what its worth the needle position makes a huge difference
if it runs well without the snorkel fitted try running the needle on a leaner setting
jonno_racing
 Posted: Mon Mar 09, 2015 6:53 am |
ATM the needle is full down. May need a smaller jet! I bought a full rebuild kit for it though so that comes with a new jet. Have now done a good 150km moving furniture and stud Its been great! I'm a huge fan of this setup. Then new found power is nice to. Something we noticed, it has a much stronger idle, it will now dry steer the 35s at idle without stalling. This wasn't possible in the past!
JrZook
 Posted: Mon Mar 09, 2015 11:02 am |
Grab an elcheapo mini drill/jet drill set off ebay and then play with the size of your main jet
jonno_racing
 Posted: Tue Mar 10, 2015 7:16 am |
Running a touch rich. I bought another set of jets and a different taper of needle. Well different number (bigger) may get a 1.25mm drill bit.
jonno_racing
 Posted: Mon Mar 23, 2015 5:46 pm |
So.. This carbi works amazing! The car will make power on nearly every angle.. I had a flop and I actually had to switch the car off as it was ideling completely on its side! There was a small amount of fuel come from the breather, just enough to smell but I couldn't see it. Best carbi I have ever driven off road. Hands down.
qwerty123
Vehicle: Coily
 Posted: Mon Mar 23, 2015 9:03 pm |
Hows it on the road? Say highway driving
Sounds great. Where did you route the overflow/Breather line too?
jonno_racing
 Posted: Mon Mar 23, 2015 10:27 pm |
In what way exactly? Its the same as the stock carbi, except better in every way. My only complaint would be the first tiny bit of the throttle is slightly touchy due to a slightly heavy stock return spring on the slide in the carby.
