It is currently Fri Sep 25, 2026 3:55 pm
Post Posted: Sat Mar 14, 2015 7:11 pm
Anyone else have this issue??
Takes a good couple of hundred goes to get the bastard to reset to zero.
Anyone fixed it???
Vehicle: SJ80, SE416
Post Posted: Sun Mar 15, 2015 2:15 pm
My Sierra and Vit both do that - both started doing it at well over 300,000km so i figured it was just a sign of parts being past their use-by.
I too am curious of a solution.
Post Posted: Sun Mar 15, 2015 2:48 pm
The obvious solution is a new instrument cluster out of a wreck... lol, but i prefer to fix it.
Post Posted: Sun Mar 15, 2015 3:07 pm
Use a gps!
Post Posted: Sun Mar 15, 2015 4:05 pm
My first one had that issue. Then my white softy developed the issue.
A new cluster fixed it.
Post Posted: Sun Mar 15, 2015 4:34 pm
I took mine apart this arvo and had a play around. Lubed everything up etc.
It's a pretty poor design. When you push the button down it's not in the middle, so the little assembly goes down crooked and jams up on the guide posts... I removed one of the return springs which helped make it track straighter and jam less (and its easier to push now too) however a quick test drive shows that while the button is now easier to push it's still jamming.
Pics:
Post Posted: Sun Mar 15, 2015 4:54 pm
So how many k's on the odometer now? :lol:
Post Posted: Sun Mar 15, 2015 5:05 pm
haha not really in my interest to change it anyway, the body is the only thing that's done that many km!!
Vehicle: 91 WT 1.6EFI
Post Posted: Mon Mar 16, 2015 8:40 pm
I have found that moving helps it reset. I reset mine on the way out of the petrol station. At the pump it will be jammed but a few hundred metres down the road it will tick over first go.
Post Posted: Mon Mar 16, 2015 10:46 pm
^^ That's how mine started...
Give it 6-12 months and you'll be in the same boat as me i reckon!
Post Posted: Sun Apr 12, 2015 10:27 pm
It seems my trip meter is working again since i lubed it up... just took a few k's to get the grease around??? Not sure... but i reset it yesterday and it was smooth as butter first go, even reset before it bottomed out!!!
Post Posted: Thu May 14, 2015 2:26 pm
Mine has stopped working now :D bugger
Users browsing this forum: No registered users and 88 guests
