It is currently Wed Nov 04, 2026 11:40 am
Vehicle: Coil Sierra
Post Posted: Sun Mar 08, 2015 5:35 pm
Ive decided to kick off my trailer build, trying to keep it light as possible but have a swing out kitchen, fuel and water storage.
The build details are:
Dimensions are 5ft x 3.5ft and the same track as my sierra.
500mm deep sides.
35x35x2 chassis
50x50x2 draw bar
20x20x1.6 frame
3 pack eye to eye springs
39 round 57" axle
215/55/15 Toyo A/T wheels and spare.
Long draw bar
Swing out tailgate.
300mm guards
L.E.D tail lights
4kg gas bottle
20L fuel
20L water
Sink
Aldi gas cooker
Bench space
L.E.D lighting
12v power
Post Posted: Sun Mar 08, 2015 5:37 pm
This was the original chassis, I later swapped the draw bar from 35x35 to 50x50 for peice of mind.
Post Posted: Sun Mar 08, 2015 5:39 pm
Tested the draw bar length and forgot to factor in the spare wheel as i wanted the tailgate to open with the trailer on.
Post Posted: Sun Mar 08, 2015 5:40 pm
The frame was added on, next was the tailgate.
Post Posted: Sun Mar 08, 2015 5:41 pm
Tailgate on, I used weld on ball bearing gate hinges.
Post Posted: Sun Mar 08, 2015 5:43 pm
Test fit to check the angle of the trailer on the sierra.
Post Posted: Sun Mar 08, 2015 5:47 pm
Next is the sides, wheel arches and cover over the top.
Rego before Easter and then the kitchen part will start, the trailer will only loose 300mm of space from the rear, the kitchen will be made of a 20x20x1.6 shs frame, a small sink, water pump tap, stainless bench and another fold out table for extra space.
Vehicle: N15 SSS (Dreaming of my Sierra
Post Posted: Mon Mar 09, 2015 1:25 pm
lookin good mate! ill be following this :)
Post Posted: Mon Mar 16, 2015 8:59 pm
Bit of an update, sides are on. Went will alloy sides and etch primed them. Mounted on guard with the gas bottle/jerry can mount sections. Still have to knock up the other side then a bit more etch priming before paint. Chose white knight kill rust charcoal hammer tone. Plan is to complete just a normal trailer then after easter the kitchen and camping stuff will happen.
Post Posted: Mon Mar 23, 2015 7:08 pm
All etch primed then first coat of charcoal hammertone.
Vehicle: 91 Tin Top
Post Posted: Mon Mar 23, 2015 8:08 pm
Looking good...
Considering the light weight materials you've used, it still looks nice and solid.
Can you fit jerry cans on the side pieces in front of the mud guards?
Post Posted: Tue Mar 24, 2015 1:50 pm
Looking good, have you weighed it?
Post Posted: Tue Mar 24, 2015 8:01 pm
I can fit one 20L jerry on each side at the front, that doubles my fuel capacity.
One the rear behind the guards will be a 4.5 gas bottle and a 10L water jerry on the other side.
The frame is split between using 35x35 and 20x20 shs, all the weight is in the wheels, axle and springs. Everything else is alloy.
Have not had a chance to weigh it yet, not sure where to go.
Post Posted: Tue Mar 24, 2015 8:04 pm
This was a test fit for the fuel and gas.
I also lowered the spare tyre holder down.
Vehicle: 91 Tin Top
Post Posted: Tue Mar 24, 2015 8:13 pm
Nice work!
Vehicle: 96 tin top sierra 31's omes
Post Posted: Thu Mar 26, 2015 11:35 am
Im a fan!
Is this for the sierra?
Are you using the standard tow bar.
Post Posted: Thu Mar 26, 2015 7:34 pm
Yeh for the Sierra, hayman reese 450kg towbar and standard hitch for now, bit of a rush to get it done before Easter.
Gone are the days of cramming two adults a 3 year old, two small breed dogs, luggage, food and tools in the sierra. Will be good to double the fuel capacity too.
All the paperwork is done for rego, just need to get a vin plate and issued vin number. Final coat is on, lights, floor and cover for the top almost done.
Still need to do a safety chain, mudflaps, reverse light and number plate light.
Post Posted: Fri Mar 27, 2015 5:32 am
Awesome! Yeah paper work was a bitch on mine. But it is awesome having a light little trailer for a small car
Post Posted: Sun Mar 29, 2015 5:04 pm
Almost there, has rego. Need to add two jerry can holders, mudflaps and seal all joins and corners with gap filler.
Used a VT commodore strut for the lid, worked out better than I thought.
Post Posted: Sun Mar 29, 2015 5:08 pm
There is a bit of technical crap involved in calculating where to mount these.
Vehicle: SJ70 1993
Post Posted: Wed Apr 01, 2015 12:12 pm
Big Fan of this Trailer :) great work
Post Posted: Thu Apr 09, 2015 10:49 pm
Thanks, it made the 550 km trip to Rainbow Beach and back for Easter. Towed really well after playing with the tyre pressure to stop it bouncing and one leaf still needs to be removed.
Post Posted: Wed Apr 15, 2015 12:24 pm
Are you still running g13ba and tcase gear?
I think i remeber reading in tour build tread about 6.5s?
Post Posted: Wed Apr 15, 2015 12:25 pm
How does the zook go?
Mine makes unhappy noises and i get worried lol
Vehicle: LWB Sierra & XL7
Post Posted: Wed Apr 15, 2015 4:11 pm
Nice work.
Good to see you have a lid for it but just be mindful, if you take the lid off, Learn from ehem... someone I know very very closely and make sure the tailgate is tied down somehow, ratchet strap, bunji cord or similar, because the tailgate may decide to eject itself from the hinge and get dragged along the ground with nothing but the numberplate light wiring preventing it from hitting other cars or people. My "mate" now always ties it down if the lid isn't on it. :roll:
'92 Vitara & Camper trailer
Post Posted: Thu Apr 16, 2015 6:56 pm
I put up with funny noises for a while as the NT transfer I was using did a bearing, did a 9 hour drive like that.
Running the G13BA which seems to be bullet proof and very reliable, 6.5 gears. I was supprised towing the trailer over Easter, sat on 110 easily but I prefer to cruise at 95.
Post Posted: Thu Apr 16, 2015 7:00 pm
buzbox wrote:
Nice work.
Good advice, might add something that only lets the tailgate lift up when open.
Users browsing this forum: No registered users and 10 guests
