[ 8 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
rwt65
Vehicle: Tin Top
 Posted: Sun May 03, 2015 10:20 am |
How do I wire G16b Injected Vitara Motor to Maruti/NT Dash cluster with Tacho? What wire off the Dizzy? Am assuming signal comes from the Dizzy. Any help appreciated
whincup
Joined: Sat Apr 17, 2010 11:30 pm Posts: 1588 Location: Gracemere, QLD
Vehicle: '94 suzuki maruti
 Posted: Sun May 03, 2015 9:40 pm |
it should already have a wire running to the dash plug in the maruti wiring harness, its just not used by the dash cluster. its just plain brown. i just tapped into that for my aftermarket tacho
rwt65
Vehicle: Tin Top
 Posted: Mon May 04, 2015 6:39 am |
I have the dash sorted, where do I hook up at the dizzy end?
chris77
Vehicle: sj413
 Posted: Mon May 04, 2015 12:24 pm |
Without seeing the wiring diagram etc but is it not as output from the ecu ? Sure there is a tach signal from the computer .
Cheers Chris
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Mon May 04, 2015 12:45 pm |
From ecu or coil Check pinouts on the ecu
rwt65
Vehicle: Tin Top
 Posted: Mon May 04, 2015 1:34 pm |
Have Tacho wire from original Sierra Loom to Tacho, (plug on right of Pic), can i take it directly to the Coil loom? (Brown White)
MrRocky
 Posted: Mon May 04, 2015 1:56 pm |
Nah im pretty sure u need to get the tacho output from the ecu The ecu will need to read the input first. Your still running the baleno dizzy or the vit ?
MrRocky
 Posted: Mon May 04, 2015 1:57 pm |
U need a diagram or pinouts
[ 8 posts ] |
Users browsing this forum: No registered users and 176 guests
