It is currently Mon Sep 21, 2026 9:37 am
Post Posted: Tue May 05, 2015 9:23 pm
Hey guys. I'm looking for a way to mount 4pt harnesses in my maruti without an internal cage.
The sides are reasonably easy, I can pick up off factory bolts and use lifting bolts (cams is ok with this)
However the rears are a bit more tricky?
Any ideas? I'd like to keep as much useable space behind the seats as I can.
Post Posted: Wed May 06, 2015 8:18 am
bolt in a harness bar mounted to the stock seat belt bolts on either side. ?? does it really need to be cams compliant?
Post Posted: Wed May 06, 2015 3:20 pm
That's fine for the lowers. The straps from over the shoulders is the issue.
Nope to cams, just using it as a guide.
Post Posted: Wed May 06, 2015 3:47 pm
nah I mean for the uppers. ill try and model what I mean
Post Posted: Wed May 06, 2015 3:59 pm
I basically mean make a bolt in taxi bar like you would have in a cage, but with brackets that mount off of the original upper seat belt bolts.
you could drop a vertical in the which bolts to the bottom seat belt buckle bolts aswell to add strength
very basic but kinda like this
Post Posted: Wed May 06, 2015 4:02 pm
Yeah that looks about what I'm thinking. Push that hard back against the cab wall.. Could just weld it in permiantly
Users browsing this forum: No registered users and 161 guests
