Print view
Previous topic | Next topic
| Author |
Message |
DarkHorse
 Posted: Sun May 10, 2015 12:46 pm |
My car is all together, but it's an hours drive away in Windsor. Do you know if someone will have an SV at the meeting on Wednesday?
Could you get spring seats and shock mounts on the GV for me as well?
got_bar_work
Joined: Sat May 15, 2010 8:30 pm Posts: 2214 Location: Brisbane
 Posted: Sun May 10, 2015 4:28 pm |
Shock mounts 1200c Coil mounts 1080
got_bar_work
 Posted: Sun May 10, 2015 4:33 pm |
The bearings are 18mm wide with a 20mm wide ring 53mm od next to it for the seal to run on
got_bar_work
 Posted: Sun May 10, 2015 4:45 pm |
The lwb housing looks the same on the outside I recon the track differences are all rim offsets Isnt somenof the gv ones p5
tanshi
 Posted: Mon May 11, 2015 8:16 am |
I think the thing your not taking into account is the front ones while not having really heavy axle weights have to be heavier duty due to the cornering stresses and having to deal with steering aswell.
front spindles I a full floater config would be fine
got_bar_work
 Posted: Mon May 11, 2015 9:05 am |
Need to find the bearing weight specs not the manufacturer aplication
tanshi
 Posted: Mon May 11, 2015 9:20 am |
try the Timken engineering manual downloadable online. or search load ratings
tanshi
 Posted: Mon May 11, 2015 10:17 am |
I have one of the 513193 hubs at home. have measured it and its around 41 wide at the bearing.
so that makes the bearings OD 63.03 bore 30 width 41
Users browsing this forum: Google [Bot] and 114 guests
