It is currently Fri Sep 25, 2026 6:30 pm
Post Posted: Mon Apr 27, 2015 7:36 pm
I've spent all day looking for info/batteries for a 1.6L Vit.
AZ Search doesn't want me to use the word "Vitara".
I want it to go here and I want it to be 75-100Ah Deep Cycle
The smallest ones I can find are 10mm too long without changing the intake, 250mm long will work. Surely someone has put a decent battery in that spot or knows of a battery.
Thanks.
Post Posted: Sun May 10, 2015 11:06 pm
What's the problem?
Can't remember the specs, but it was the same physical size as the stock battery... with the isolator in front and the compressor next to it.
Vehicle: Suzuki Jimny 2013
Post Posted: Mon May 11, 2015 7:20 am
I think from memory the century/Delco deep cycle 250mm long battery was about 60-70ah. optima d34 is only 55 ah 250mm long, but only 190mm to top of terminals, so good for a jimny...fast charging too apparently.
Post Posted: Tue May 12, 2015 5:23 am
80Ah. 260x170x215. I need to change the intake and move the coil though. It's too tight a fit.
Post Posted: Tue May 12, 2015 10:54 am
Needs more 33 10.5 :thefinger:
Post Posted: Tue May 12, 2015 4:10 pm
Needs more body drop and cantilever
Post Posted: Tue May 12, 2015 7:15 pm
Century Deep Cycle, NS70T 75Ah - 260 (L) x 171 (W) x 202mm (H)
http://www.supercheapauto.com.au/online ... mendations
Might be an option?
Post Posted: Tue May 12, 2015 8:56 pm
The picture I posted is of my car and the battery I bought.
$170, 80Ah. She'll be sweet.
Vehicle: sj80 w/myside2. 99GV 2.5V6
Post Posted: Wed May 13, 2015 1:53 pm
If thats an AGM it wont like being so close to the exhaust manifold
Post Posted: Wed May 13, 2015 6:14 pm
It'll be protected.
Vehicle: SWB Vitara
Post Posted: Thu May 14, 2015 7:02 pm
620CCA, no idea of amp-hours.
Post Posted: Thu May 14, 2015 7:41 pm
That's the other intake setup and stock position for that model, right?
Post Posted: Fri May 15, 2015 1:24 pm
Yeah-that's the later model injection.
Users browsing this forum: No registered users and 102 guests
