It is currently Fri Nov 13, 2026 8:59 pm
Post Posted: Mon Mar 30, 2015 8:05 pm
got some bits and peices left over from parting out my old vit. I'm moving house soon so i need to off load some stuff otherwise some will end up at the dump. I Got.
5:12 front diff complete (sorry alloy housing): $50
rear 10 bolt 5:12 ring & pinion: $15
I have some s.e front a arms: free
vit rear housing: Free
I have a transfer case mount the good type suit someone with a lwb with one of the shitty channel type mounts: $15 sold.
One drivers side 22 spline drive shaft good for a spare: $20.
s.e transfer case: $50
lwb fuel tank has dints no leaks has working pump and indicator: $10 gone to tip
think that is all.
Post Posted: Thu Apr 02, 2015 7:15 pm
how much would it cost to get the front arms posted to perth 6065? to heavy??
Post Posted: Thu Apr 02, 2015 7:34 pm
i can get a quote next week for you. i think it 20 something kgs
Post Posted: Thu Apr 02, 2015 7:40 pm
ok, are they in good condition? not bent or damaged? as they will be replace my current set and dont want them if they are going to cause other issues.
cheers
Post Posted: Sat Apr 04, 2015 2:31 pm
Not bent I can get a pic for you if no one wants them they going to the tip
Post Posted: Sat Apr 04, 2015 2:32 pm
Pm me your number and I'll text you pic
Vehicle: 1992 suzuki vitara
Post Posted: Sat May 23, 2015 8:35 pm
do you still have diff, free wheeling hubs?................I can be contacted on 0429990597.cheers brad
Post Posted: Mon May 25, 2015 2:47 pm
Will you post the vitara front diff? Willing to post at my cost?
Post Posted: Mon May 25, 2015 2:52 pm
I only need the front r&p. Postage will be cheaper
Vehicle: 2001 M15A Jimny
Post Posted: Mon May 25, 2015 7:37 pm
Do you happen to know of hand if the transfer case (or the chain) would fit a MT Jimny?
Post Posted: Fri May 29, 2015 7:31 pm
pm'd dono1
jimny_no_power i believe that the vitara are gear driven. and i from what i understand you would be better off doing a sierra transfer case conversion gives you more options for gear reduction.
Users browsing this forum: Google [Bot] and 20 guests
