It is currently Sun Nov 01, 2026 7:24 am
Vehicle: 88 Sierra
Post Posted: Wed Jun 10, 2015 2:48 am
Hi all...
This is my first post so I thought I would start with my home made conversion. I know many people say turbo charging a 13a is pointless and unreliable but I like to tinker and I had the car and all the bits. I actually have had the car since near new - an 88 sierra with now 220k on the clock. Its been handed down and recently retired for the occasional bash on the beach. I always wanted to turbo a carby car and this was more an exercise to see if I could do it cheaply and actually make it work.
So firstly let me say the entire conversion cost me $500. Everything was fabricated in my garage and yes, it works! Surprisingly the power increase makes the car drive like a dream. Smoother, torquey and sounds ridiculous haha. Using the ass dyno i would say a conservative 30% increase in power. It actually moves out nicely :)
Toyota CT12 turbo running 5psi
S13 intercooler
webber 32/36
Electric pump/boost ref reg
So to keep it cheap and easy, I fabricated a 'J-pipe' to mount the turbo. Basically a piece of pipe from the standard exhaust manifold to the turbo. Added a bracket at the top to stop it moving then smashed out a dump pipe, cut up an old 2.5" exhaust system and plumbed up the lines. To avoid the $100 drain line from the local fitting place, I used copper pipe from bunnings and just braised fittings on and tapped a brass fitting into the sump. Water is easy to source and the oil feed came from the spare bung next to the oil pressure switch.
As for the carb, I filled the floats and copper coated all the gaskets. Boxed it up and bolted it on.
Fuel was simple - used a 14psi electric inline pump, swapped the breather and return lines around (the breather is twice the size) and used a boost referenced reg to send the unwanted fuel back. Base psi is about 4.5 and it rises 1:1 as boost increases.
I got most bits of gumtree and what I had laying around. It was fun and definitely worth it!
That picture is before I finished it... It now has the intake and the rocker cover breather feeds into the turbo inlet. This was essential as the crankcase would pressurise and pump smoke out the back on boost. And just in case you are wondering, I have been driving it everyday and I have not had a single issue... The little zook has a new lease on life.
Any questions, ask away!
Mike
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jun 10, 2015 8:32 am
can we has pictures?!
Vehicle: Which one?
Post Posted: Wed Jun 10, 2015 8:34 am
There's one right there in the OP.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jun 10, 2015 10:07 am
bummer
Vehicle: Which one?
Post Posted: Wed Jun 10, 2015 10:57 am
How's that.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jun 10, 2015 1:48 pm
thanks Henno! did well to keep it under $500
Vehicle: 88 Sierra
Post Posted: Fri Aug 28, 2015 10:30 pm
It has been revised... jets, fmic and filter relocation. 101hp @ the wheels pushing 8.5psi!
Post Posted: Fri Aug 28, 2015 10:58 pm
Sweet, 101hp atw is very respectable for a Suzuki! Do you have a dyno graph? What revs does it make full boost at?
Vehicle: 88 Sierra
Post Posted: Sat Aug 29, 2015 1:10 pm
Its the rears, not all four. But yeah, makes full boost about 3.5 and then spikes at 5.5. It did lean out top end so if i somehow get the fuelling right I would expect a drop in power. The bigger intercooler made the boost curve much nicer as that turbo is tiny
Vehicle: MG410 Gypsy
Post Posted: Wed Sep 02, 2015 9:43 am
please post a video of this running/boosting. would love to hear it....
Vehicle: 88 Sierra
Post Posted: Sun Oct 11, 2015 7:41 pm
Finally got a video up...
Vehicle: zook
Post Posted: Sun Oct 11, 2015 7:49 pm
Hah! that is pretty awesome.
Fingers crossed everything holds together for a while.
Vehicle: Mighty Boy / LJ81 Hybrid
Post Posted: Thu Oct 15, 2015 3:50 pm
I Stumbled on your youtube video yesterday. Still looking sweet!
Where are those dunes?
Post Posted: Fri Oct 16, 2015 8:50 am
sounds great, well done mate.
Vehicle: twin cam, twin locked, turbo
Post Posted: Thu Dec 17, 2015 5:59 pm
Awesome.
Post Posted: Sat Dec 19, 2015 11:35 pm
hah! that's quick! =)
You're going to get yourself into trouble! lol
Vehicle: Vitara 1994
Post Posted: Mon Jan 04, 2016 4:57 pm
Well done! looks like a lot of fun!
Post Posted: Tue Jan 05, 2016 8:18 pm
looks good - but it might be an idea to scratch out your number plate in the photos!
Post Posted: Tue Mar 01, 2016 9:55 am
That's 75kw which is quite impressive! For reference I managed to get 47rwkw out of my G13 with a webber/exhaust etc.
Vehicle: Suzuki Jimny 2013
Post Posted: Wed Apr 27, 2016 1:16 pm
Any chance of one for an M13A vvt?
Post Posted: Wed Apr 27, 2016 8:26 pm
Is this the one that fell over on the weekend?
Vehicle: 89 suzuki sierra
Post Posted: Fri May 27, 2016 9:16 am
Looking at doing the same to my 13a, curious to know what the float was filled with? Also is it just bolted to the top of it, looks like it is via picture and explanation of it just want to make sure.
Vehicle: 98 Jimny
Post Posted: Mon May 30, 2016 11:05 am
Is your Sierra geared?
Displacement is no replacement for gearing. Then I'd look at putting a turbo on it if you really felt the need to. IMO, our local terrain doesn't call for more power.
Vehicle: 1995 Sierra
Post Posted: Mon May 30, 2016 12:41 pm
were any adjustments made to the ignition advance?
Post Posted: Sat Jun 11, 2016 9:27 am
To the best of my knowledge, a small hole is usually drilled in the float, the float is filled with expanding foam, and then any foam extruding from the hole is sanded smooth again. The Idea is to stop the float being crushed with the increase in pressure, however I wouldn't have thought it necessary only running relatively low boost pressures on a good condition weber float, perhaps Hos floats were cracking and showing signs of age? Still a cheap and easy mod to perform, cheap insurance I guess.
Although bolting charged air duct-work straight to the intake of the weber is possible with further modifications to the carburetor, usually called 'boost referencing'. In this instance Hos has 'boxed' the entire weber, everything from the intake manifold up is incorporated in an air tight box which is plumbed to the turbo. This overcomes the problems caused by the pressure difference inside and outside of the carburetor, you just have to make sure everything that needs to run to carburetor, throttle cable, fuel lines, ect are well sealed into this box.
Users browsing this forum: No registered users and 24 guests
