It is currently Fri Aug 07, 2026 6:55 am
Vehicle: Suzuki Sierra 1997 Soft Top
Post Posted: Tue Aug 04, 2015 1:02 pm
Hi I'm Fozzy from around Cockburn area. So after many years of awwing and ahhing about getting a zook I finally got one.
I've been looking through good tech stuff and thought I'd do an oil change. It all went good but heard a squealing noise and a lot of vibration coming from the distributor assembly after I replaced oil and oil filter. Went through the service manual and opened it up.
Is that normal wear and if not what parts should I replace?
I put the assembly back in as per service manual but when tightening the bolt it cracked, is this an easy fix or should i just replace the whole thing?
Sorry for the long first post, I've been reading through a lot of the threads and making a new thread was the last thing I wanted to do as I know it is a pain in the arse if another thread has already solved the issues.
Look forward to your replies
F.
Vehicle: Coily.
Post Posted: Tue Aug 04, 2015 9:45 pm
Welcome Fozzy,i can't help,our Coily has done 200,000 so your Dizzy looks OK.
Post Posted: Thu Aug 06, 2015 10:30 pm
Could anyone shed some light on how to fix the mount where the bolt goes into? It's come off completely. I haven't driven it since but did use vice grips on it just to make sure it did run.
F.
Post Posted: Fri Aug 07, 2015 7:52 am
Change your subject on the thread to something more descriptive and you might attract the right person to have a read =) Just edit the original post.
Post Posted: Sat Aug 08, 2015 12:34 am
What sort of light do you need shed - it's broken - it needs to be replaced.
It's bolted to the back of the head, unbolt it, remove, fit replacement (new O rings would be a good idea whilst you have it out) - if you can't find a replacement, it might be possible to have it built up by welding, refacing and then drill & tap a hole - but, I suspect that will be a fairly expensive approach.
Post Posted: Sat Aug 08, 2015 2:13 am
Yep ^
I'm sure plenty of people on here will have spares, if not you can buy them new from lror.
http://www.lowrangeoffroad.com/suzuki/s ... using.html
I might have a spare one off an F10a. I'll have a look.
Post Posted: Sun Aug 09, 2015 6:28 am
I would check that the bolt is the correct length, it may have bottomed out.
Post Posted: Sun Aug 09, 2015 11:00 am
Thanks for your replies, now that I know what I'm looking for I can go forward.
@Rhinoman the bolt is the original I'm assuming plus the cracked part of the flange came off completely.
@sideways that would be awesome if you have a spare. Is the part compatible with the 1.3L G13BA engine?
The engine oil level is right on full, will there be overflow of oil when removing the housing?
F.
Post Posted: Wed Aug 12, 2015 11:17 am
Replaced the housing and o ring now doesn't make any squealing noises. Winning!
Users browsing this forum: No registered users and 43 guests
