It is currently Tue Nov 03, 2026 1:29 pm
Post new topic Reply to topic  [ 91 posts ]  Go to page Previous  1, 2, 3, 4  Next
Post Posted: Tue Jan 05, 2016 4:56 pm
Jack Apgar was the last good engineer... He would have been crazy enough to consult on something like this i reckon.
Vehicle: 92 vitara
Post Posted: Tue Jan 05, 2016 5:22 pm
Ok thanks mate obviously he not around anymore? I will c what happened I no it prob won't I'm not doing any chassis mode eg welding or drilling only on diffs and prob gearbox tunnel no lift kit maybe a body one so I don't have to put lump in bonnet the triton stuff is amazingly similar even the gearbox mount will need minimal mod same with engine mounts
Post Posted: Tue Jan 05, 2016 6:57 pm
Weight and power willl kill the project before chassis welding. Chassis welding etc is no issue for engineering.
Vehicle: 2001 Grand Vitara
Post Posted: Wed Jan 06, 2016 10:09 pm
Great project!
I've done a UZ conversion (in an MA61 celica supra) and built a lotus 7ish from the ground up (chassis fabrication included)
Both of these were/are fully engineered and legal in WA...
However...there's a weight/power calc for permissible engine size, a quick google will find it. I'm pretty sure a Vitara is too light for a UZ.
If you've got any questions about engineering/certification, I'll help where I can...
Vehicle: 92 vitara
Post Posted: Thu Jan 07, 2016 4:13 pm
Thanks mullet much apretiated mate I'm in the process taking sump off and rearranging for diff
Vehicle: 92 vitara
Post Posted: Thu Jan 07, 2016 4:38 pm
[url][/[URL=http://s1074.photobucket.com/user/wheatbelttyresockman-500/media/image_zpsrkyhm8ky.jpeg.html]Image[/url]]vitara weigh 1005kg ? What Google says this code table meens u can put a bit over 4ltr but I read on and it says it doesn't apply to 4x4 anyways I'll keep plodding along
Post Posted: Thu Jan 07, 2016 5:07 pm
Yeah...It's amazing what you can get away with in a 'commercial' vehicle!
You can also choose the heaviest, factory quoted weight. IE if you can find a brochure or something that lists it at 1100kg, you can have a 4.4L V8. Either way, if your factory weight is 1005kg, you could, theoretically fit this engine legally. Which would make me lose my sh*t.
Vehicle: 92 vitara
Post Posted: Thu Jan 07, 2016 5:17 pm
Hahah oh ok I'll have to look into that find a brochure the 1uz is only 3998 cc so cool little motor
Vehicle: Vitara 1994
Post Posted: Fri Jan 08, 2016 3:01 pm
Mullett86 wrote:
Great project!
It's the LS1's that people run into problems when trying to engineer, the 1uz should be ok.
It's a cool project and the best choice of v8 for a little vit
Vehicle: 92 vitara
Post Posted: Fri Jan 08, 2016 3:16 pm
Would the ls1 even fit between struts it's a bloody wide motor with exhaust manifolds on
Post Posted: Fri Jan 08, 2016 3:45 pm
I think it probably would, if the UZ does. The UZ is not a compact motor by any means...someone said to me once that it occupies a cube 800x800x800, and I think they are pretty close to the money. Twincam heads are very space hungry...
Post Posted: Fri Jan 08, 2016 3:55 pm
LS motors are super narrow for the size of the motor.
they fit in a sierra chassis after all
Vehicle: 92 vitara
Post Posted: Fri Jan 08, 2016 6:34 pm
Yeah true the heads are big I have tacked up engine mounts tday motor and box fitting snugly in chassis now done lots of measuring. Think tunnel will only need a lump for hydraulic clutch slave cyl other than that think body will fit back on snug
Post Posted: Fri Jan 08, 2016 11:26 pm
The 1uz is much wider than an LS1. It's not really the width that is the issue with a vitara, its the length and yes LS1's have been put into vitara's but normally 2wd only which is pointless imo
Post Posted: Fri Jan 08, 2016 11:39 pm
You can always do a 2 inch body lift to make it all fit better. I am almost sure you will have to in order to shut your bonnet and clear your diff. I have hydro clutch conversion on mine, a hack job done by the previous owner, he beated in the footwell, if he did the body lift everything would have fit better. I also needed a 2 inch body lift to get the sr20 to to clear the diff and fit under the bonnet, I suspect you will need the same. With diff drop brackets it might have fit, but you will still run into problems where the back of the diff is mounted to the crossmember. A 2 inch body lift will also open up radiator options, easier hydro clutch conversion, tire and wheel options etc
Post Posted: Fri Feb 05, 2016 2:13 am
Any progress on this?
Vehicle: 92 vitara
Post Posted: Tue Feb 09, 2016 12:04 pm
Gday mate I have fully fabed engine mounts now just been busy at work I'm in country wa so fire bans have been on for hot weather so caint weld or grind I'm still looking for a 1uz computer setup if anyone on here is computer savvy cheers
Vehicle: 92 vitara
Post Posted: Wed Feb 17, 2016 8:39 pm
[url][/url]Image
Vehicle: 92 vitara
Post Posted: Wed Feb 17, 2016 8:40 pm
[url][/[URL=http://s1074.photobucket.com/user/wheatbelttyresockman-500/media/image_zps0qctxzl6.jpeg.html]Image[/url]]
Vehicle: 92 vitara
Post Posted: Wed Feb 17, 2016 8:45 pm
[url][/[URL=http://s1074.photobucket.com/user/wheatbelttyresockman-500/media/image_zpssdmrxc1s.jpeg.html]Image[/url]]so mate came round tday to drop body on to see how we go as thawt need slave cylinder cut in floor and Rhs rocker cover will need modifying for booster but other than that looking great for fitment dose not clash with bell housing which was my big consern will need 3 inch body lift tho getting there anyways
Post Posted: Thu Feb 18, 2016 2:12 am
I would consider going straight to an aftermarket computer. The stock computer is tied in with the auto trans and has to have some wiring wizardry to work. So by the time you buy and wire there wont be much in it when compared to an aftermarket option. Just a adaptronic or sprint 500 will do
Vehicle: 92 vitara
Post Posted: Thu Feb 18, 2016 10:00 pm
Gday vet I ended up buying a whole other engine with all the bits it had been over heated so computer wiring injection all unmolested I fired up body today had to trim firewall for rocker covers and clutch slave cyl e
Post Posted: Sun Feb 21, 2016 4:01 pm
Got any pics of the trimming?
Vehicle: 92 vitara
Post Posted: Mon Feb 22, 2016 12:43 pm
[url][/url]Image
Post Posted: Mon Feb 22, 2016 4:30 pm
Wow..
Umm where is everything going to fit exactly? Radiator and fans i mean
Love the idea and build though
Vehicle: 92 vitara
Post Posted: Mon Feb 22, 2016 7:12 pm
[url][/[URL=http://s1074.photobucket.com/user/wheatbelttyresockman-500/media/image_zpsfnuajdod.jpeg.html]Image[/url]]
Vehicle: 92 vitara
Post Posted: Mon Feb 22, 2016 7:18 pm
Gday yeah all going smoothly rad will be custom as will need small and fat but ac condenser will fit to fan will be on outside pushing in custom cowling my best mate is a auto sparky so all wiring and computer covered now he is splicing up a harness at the moment body going to my uncles soon to get bead blasted and going to paint frog green as me and the wife like that colour also they do a new ute coating called raptor by u-pol it's a body deadner but tintable so going to do firewall floors inside and out green so I don't have to have carpet just floor mats
Post Posted: Mon Feb 22, 2016 9:30 pm
That looks alright sealed up.
I assumed you started cutting after the 3 inch body lift you mentioned earlier? Or are you not going to run a body lift anymore?
It's coming along great. Look forward to the finished product
Vehicle: 92 vitara
Post Posted: Mon Feb 22, 2016 10:11 pm
Yeah it's actually sitting at 90mm at the moment could drop maybe 15 mm but bonnet won't close I'll have to wait to see what engeneer suggests I just got sheet metal and used old roo bar as a pipe bench to hammer curve in steel ahahahah works ok need mate to come round again to help lift body off so I can weld and grind outer firewall
Vehicle: 92 vitara
Post Posted: Wed Mar 16, 2016 10:26 pm
[url][/url]Imagebody ready to go to my uncles fri for metal blast so lite now two blokes lift it hahahah
Users browsing this forum: No registered users and 12 guests
