| Author |
Message |
adamess
Vehicle: Jimny Sierra 2015
 Posted: Wed Jan 13, 2016 5:57 pm |
Hi guys, needing some advice re traction control. I have a 2015 jimny sierra auto. On the soft sand the TC kicks in all the time and almost brings the car to a stand still via braking etc. It can be disengaged by holding the button on the dash but it automatically re-engages after 30km/h. Is there a way to override this that anyone is aware of? This feature appears to be permanently disabled in low range but is not a practical solution for higher speeds beach driving. Any advice much appreciated! Adam
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Wed Jan 13, 2016 10:29 pm |
There's likely a fuse you can pull to disable it? Not sure what else that'd mess with though, and you'd want to be sure to re-engage it, cos im pretty sure your insurance would be null and void in a crash if they found out!
adamess
 Posted: Thu Jan 14, 2016 5:00 pm |
Hi mate yeah its a tricky one wrt warrantys and insurance etc. From what I've read the TC systems are pretty basic and mainly introduced to comply with safety regs. It kicks in mainly when trying to steer left or right out the already deep and worn tracks on the beach, say if there is someone coming from the other direction following the same worn track. As soon as the tires start to bite into the edge the TC sort of guesses something's wrong and starts breaking the wheels randomly to compensate. I'm pretty sure engine power is cut also in conjunction with this. Excellent car and I cannot fault it apart from this.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13008 Location: Melbourne
 Posted: Fri Jan 15, 2016 7:17 am |
I don't know what effect pulling the ABS fuse will have on warranty, I can't imagine any at all, or if ABS function is data logged as part of OBD.
Perhaps using a scan tool will assist in that.
The obvious "fix" is just pulling the ABS fuse. I believe plenty of warning lights light up under these circumstances.
adamess
 Posted: Wed Jan 20, 2016 5:10 pm |
thanks guys will look into the fuse thing, also may contact Suzuki to see if there is a way to disengage TC.
Gwagensteve
 Posted: Wed Jan 20, 2016 6:49 pm |
Sloba
Vehicle: 2015 jimny
 Posted: Thu Jan 21, 2016 1:24 pm |
vet 180 wrote: Rhinoman wrote: Does the ESC work in 4-low? According to the manual ESC is turned of and brake traction control is activated. Tbh I am not even sure mine even has esc on high range as I have need felt it kick in and there is no button to turn it off and I never see the light turn on even when I switch on the ignition. But I do feel the brake TRC kick in when low range is engaged. my 2015 jimny definitely has a button to turn ESC off to the right hand side of the steering wheel where the buttons go. You have to hold the button in for a few seconds i discovered I think. A light then comes on the dash when its off. I *think* I recall it automatically turn off in low rang and the light comes on the dash, cant remember without looking really though... I haven't taken my jimny on the sand yet but from my experience in my d40 navara when in high range in the sand the ESC was on unless you manually turned it off and it was a pain in the ass, pretty much made me get bogged in the soft stuff. So much better once I turned the ESC off. cheers, Mark
jdk81
Joined: Sat Jul 18, 2009 11:30 pm Posts: 2372 Location: Ballarat, VIC
 Posted: Thu Jan 21, 2016 2:32 pm |
Is it possible to wire in a switch to make the car think it's in low?
I'm thinking you could make it so the switch can only be used when the car is in h4 by using a relay.
alien
 Posted: Thu Jan 21, 2016 2:35 pm |
Doesn't it automatically turn back on over 30km/hr even in low range though?
Wouldn't be too hard to get a little bit stuck at have the wheels spin at 30km/hr, re-engaging it and getting you more stuck or at least not helping the situation.
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Thu Jan 21, 2016 4:49 pm |
Sloba
Vehicle: 2015 jimny
 Posted: Thu Jan 21, 2016 6:29 pm |
What a pain in the ass definitely need a way to stop it coming back on at 40kmh for sand driving. I didn't think it did one back on over 40kmh in low range? Will have to test it
adamess
 Posted: Thu Jan 21, 2016 6:42 pm |
In low range it switches off automatically and the little light on the dash comes on to let you know its off. As far as I can tell there is no way to disable it in high range, unless you are going under 40ish k's an hour and then it'll come straight back on after you exceed this speed. Ive tried to turn it off even when driving around town in 2wd and it won't turn off if you're going over 40k's.
Sloba
Vehicle: 2015 jimny
 Posted: Thu Jan 21, 2016 7:26 pm |
Adamess do you know if it comes back on over 40kmh when in low?
adamess
 Posted: Thu Jan 21, 2016 7:34 pm |
Almost positive that it doesn't. It disengages automatically when LR is selected and as far as I can tell does not come back on. I had to use LR on Bribie just recently it was high tide and there were hundreds of 4wd's on the beach couldnt afford to bog down with traction control jitters if I was trying to get out of /someones way coming from the other direction. I wouldnt have been going much faster than 40 for sure and I'm assuming this is not recommended for long periods of time because of the higher revs etc. Its an Auto btw not sure how the manuals go with the TC.
MrRocky
 Posted: Thu Jan 21, 2016 7:57 pm |
Yup comes back on over 40 even in low read the manual
MrRocky
 Posted: Thu Jan 21, 2016 7:58 pm |
Sloba
Vehicle: 2015 jimny
 Posted: Thu Jan 21, 2016 8:29 pm |
Well that Sucks. Pull the fuse when I let the tires down I guess
Qthefun
Joined: Wed Nov 25, 2015 8:07 pm Posts: 332 Location: Brizzy
Vehicle: Suzuki Jimny Sierra 2015
 Posted: Thu Jan 21, 2016 9:18 pm |
sounds like I am in for fun when I do my first beach trip lol
adamess
 Posted: Thu Jan 28, 2016 7:45 pm |
Yes you might be haha let me know how you go.
Completely disabled in low range regardless of speed btw.
Sloba
Vehicle: 2015 jimny
 Posted: Fri Jan 29, 2016 9:59 am |
adamess wrote: Yes you might be haha let me know how you go.
Completely disabled in low range regardless of speed btw. So you can go over 40khm in low range and it won't come back on in your 2015 auto jimny? MrRocky said different above and indicated the manual even says it comes back on in low over 40kmh .. Guess I'll also just have to try it in my 2015 jimny and see how it behaves in low over 40kmh. cheers, Mark
Pete The T-Rex
Vehicle: 2015 Jimny
 Posted: Wed Jun 22, 2016 8:52 pm |
Sloba wrote: adamess wrote: Yes you might be haha let me know how you go.
Completely disabled in low range regardless of speed btw. So you can go over 40khm in low range and it won't come back on in your 2015 auto jimny? MrRocky said different above and indicated the manual even says it comes back on in low over 40kmh .. Guess I'll also just have to try it in my 2015 jimny and see how it behaves in low over 40kmh. cheers, Mark Hey Mark, How did you end up going? Any luck figuring out the limitations?
Sloba
Vehicle: 2015 jimny
 Posted: Sat Jun 25, 2016 12:21 am |
To be honest I haven't even taken the Jimny on the beach yet still haha
