It is currently Wed Sep 23, 2026 12:29 am
Vehicle: 1995 Sierra
Post Posted: Mon Feb 15, 2016 3:34 pm
im sure someone has asked this before but i couldnt find any threads on it
some useless idiot has cranked the fill/drain plugs on my diffs so hard i dont think anything anything short of drilling them out will budge them.
ive tried heating them, ive tried hammer and chisel, ive even tried using a car jack to lever the wrench but all it does is lift the car off the ground.
before i set fire to the thing, is it fine to drain the diff by pulling the axles and centre out and refill it through the breather port?
Vehicle: Which one?
Post Posted: Mon Feb 15, 2016 3:37 pm
Weld a nut in/on there and rattle gun the fuckers off and replace them?
Lifting the car before they budge is crazy though.
Post Posted: Mon Feb 15, 2016 3:38 pm
I've had success with welding a nut to the plug and using a socket on it.
If you do end up pulling axles and centre out (big job) then find out an accurate amount to refill it with so its not over or underfilled
Post Posted: Mon Feb 15, 2016 3:46 pm
ive only got a stick welder, i dont think i could get a decent enough weld to hold. i might just take it to a mechanic, not the same ones that put the fuckin things in though. they are well and truly in there, im actually concerned i might break the socket or damage the diff housing if i put anymore force on.
Vehicle: WT sierra, GU CRD
Post Posted: Mon Feb 15, 2016 3:54 pm
Dumb question: you're using the flash square tool on the plugs?
If so, and if you haven't tried it already, I'd hook it up to an impact (although I will thoroughly admit this is rough, may break the plug or the tool)
Or try welding a nut.
I love ZD30. :)
Post Posted: Mon Feb 15, 2016 4:17 pm
yeah im using the 10mm socket, the plugs were pretty much ruined anyway from someone previously using the wrong socket. ive tried my 18v impact and it wont budge them.
Post Posted: Mon Feb 15, 2016 4:38 pm
Just make sure it's genuinely a 10mm key, and not a 3/8 drive. Small difference in size but big difference in damage to the plug. I'm sure you already know.
Edit: oops sorry, jimny. I had my mind on Sierras which are a 10mm key, not a socket
Vehicle: Suzuki Jimny Sierra 2015
Post Posted: Mon Feb 15, 2016 7:47 pm
silly question but have you tried tightening a little first after a good soak with WD40 or similar?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Feb 15, 2016 8:23 pm
Yield
https://www.chemsearch.net.au/pages/pro ... g&pid=5068
Post Posted: Wed Feb 17, 2016 6:01 pm
success finally! biggest easy out i could find, a breaker bar and some persuasion has finally got it, only problem is the plug is completley ruined haha. any ideas where to get a replacement?
Post Posted: Wed Feb 17, 2016 7:48 pm
Jezza86 wrote:
This stuff is the shit!! Armsup
Vehicle: SJ80, SE416
Post Posted: Wed Feb 17, 2016 10:01 pm
Hopefully this link works...
https://www.suzistore.com.au/four-wheel ... 1-100.html
This mob are great to deal with online. There are probably cheaper places to buy from but this place is a great start.
Users browsing this forum: No registered users and 63 guests
