It is currently Mon Sep 21, 2026 10:55 pm
Vehicle: suzuki jimny
Post Posted: Sat Feb 20, 2016 1:43 pm
have my plans all drawn up with measurements but im undecided on material. originally i was going to go with qubelok (or connect it from bunnings) but blew out the budget at the moment. 12mm MDF is really cheap (can get the sheets i need for under $40) but im unsure that over time and with all the stuff on top of the drawer will take he weight not saying im putting a ton of stuff on though.
a mate of mine has a drawer made of plywood in his GU which made me think about which is best. looked into plywood and its only $46 for 2400mm x 1200mm x12mm and did a bit of searching around as to what wood is best but no real answers.
Post Posted: Sat Feb 20, 2016 7:31 pm
I would use formply for that application. It's dearer but the hard black facing is basically ready to go and requires no further preparation.
I would not use MDF.
Vehicle: Suzuki Jimny 2009
Post Posted: Sat Feb 20, 2016 8:08 pm
Definitely not MDF. Apart from being dangerous stuff to work with (carcinogenic dust) is is quite weak. Use plywood, it is much stronger and safer.
Vehicle: LJ80
Post Posted: Sat Feb 20, 2016 8:09 pm
I would not use MDF either . I am using 12mm ply in 2400 x 1200 for $39.10 each at the moment with clear or paint to seal it .
Vehicle: Which one?
Post Posted: Sat Feb 20, 2016 8:17 pm
If you so much as sneeze near MDF the moisture warps it.
So yeah, what these dudes ^^ said.
Post Posted: Sat Feb 20, 2016 9:38 pm
MDF won't work. Screws will pull out with vibration. Any moisture will kil it
Vehicle: Suzuki Jimny Sierra 2015
Post Posted: Sun Feb 21, 2016 1:41 pm
MDF is only good for turning off cuts and dust into money for those who sell it!
What ever you use look at weight, water resistance and long term reliability!
Post Posted: Sun Feb 21, 2016 6:31 pm
plywood it is. thanks for the advice everyone hopefully in the next couple of weeks i should be able to go get the sheets and make the base.
Users browsing this forum: No registered users and 73 guests
