Vehicle: 92 suzuki sierra
Posted: Tue Apr 26, 2016 12:31 pm
Hi guys over the weekend i installed a spartan auto locker in the rear of my zook.. well i helped my dad and his mate did most of it.. and i took it for a spin and it wont unlock..ever..it just scrubs the tyres around corners.. it didnt come with any instructions at all so im going to pull the center out again this arvo and make sure we didnt leave the thrust washers in.....any thing else i can check?? how can i check it on the jack stands to make sure its un locking?? thanks in advance
contrary to popular belief on this forum... these are not meant to be locked at rest, the pinion is what locks them once you are driving andforce is applied to the oval pinion hole.. that being the case you should be able to jack the diff up (obviusly being sure to do it on flat ground and front wheels chocked so it wont roll anywhere/on you) and you should be able to turn one wheel forwards while someone else is turning the other wheel backwards.
if you turn them both the same way then it will lock the centre against the pinion shaft which is how htey "automatically lock"
video below explains very well exactly how they work inside the car.
Posted: Tue May 03, 2016 4:11 pm
HA! sorted i left the thrust washers in. there does seem, to be a bit of back lash not in the crown wheel and pinion but in the locker its self to the axles... it might wear in.. i dunno.... sorry one quick one guys.. if i order another for the front is it the same 26 teeth ??
Only if you have upgraded front axles. The standard front axles are 22 spline. I wouldn't bother putting a locker in the front end of a car with standard 22 spline axles.
Lash is normal - note how the cross pin isn't a tight fit in the two couplers? that's where the lash is coming from. It's what applies force to the dog teeth as torque is applied in order to prevent the locker disengaging.
Ah, so what you are saying is that when torque/drive is applied, the cross pin forces itself against the cam gear 'locking' the dog teeth.
Users browsing this forum: No registered users and 44 guests
