It is currently Wed Sep 30, 2026 3:33 pm
Post Posted: Tue May 10, 2016 8:35 am
Does anyone have any pics of the assembled kits. About to fit them to a spare housing and can't see how it all goes together.
Post Posted: Sat May 14, 2016 11:28 am
Slowly getting there with zero info. So far have had to mod every part including the diff housing.
Does the original wheelbearing get used or is the axle now supported by the diff centre and the centre bearing in the stub axle
Post Posted: Sat May 14, 2016 4:12 pm
Original wheel bearing should be discarded - that's what makes the axle fully floating.
Post Posted: Sat May 14, 2016 4:36 pm
Bugger. Ball was right.
Post Posted: Sat May 14, 2016 7:02 pm
Im unsure on which model you recieved but if you go through my build thread you will see all that i had to modify
Post Posted: Sat May 14, 2016 7:24 pm
:thefinger:
Post Posted: Sat May 14, 2016 7:39 pm
Most of the issues I have had so far involve fitting it around the abs bits. The kit must have been for a non abs diff.
Even down to one of the stub axle bolts hitting the lumpy bit on the diff where the sensor goes.
Post Posted: Fri Aug 12, 2016 3:21 pm
Not a chance that this kit can be fitted to a jimny with abs. But pissed off that I have wasted money and time on it
Post Posted: Fri Aug 12, 2016 3:40 pm
On the up side, at least you can re-sell it to re-coup costs?
Post Posted: Fri Aug 12, 2016 3:55 pm
yeah that's a shame, it can be pretty hard to get the bolt to clear but ive managed it with mine. just need to mill a bit out of the floater adapter on mine to clear the abs bung
Post Posted: Fri Aug 12, 2016 6:14 pm
I have everything fitting except for the abs ring. Cbf making new axles.
Post Posted: Fri Aug 12, 2016 6:24 pm
What choices are there for rear disks on a abs jimny? Don't really care to much about full floater.
Are there any actual kits that fit and use Nissan callipers?
Users browsing this forum: Google Adsense [Bot] and 157 guests
