It is currently Wed Sep 23, 2026 4:07 am
Vehicle: suzuki sierra sj70 soft top
Post Posted: Sat May 21, 2016 9:33 am
hey all i have no lift and 31s and alot of tyre rubbing! i want to chop my guards but i also want some advice on it due to i have never done it before? cheers all and tips and hints help :D :D :D
Post Posted: Sat May 21, 2016 10:59 am
Have a good search for "virtual lift" - That's how it's commonly referred to on here.
There are MANY different methods - from quick and rough to very, very time consuming and neat.
Post Posted: Sat May 21, 2016 11:01 am
I punched "virtual+lift sierra" into the search engine and got this thread straight away.
viewtopic.php?f=5&t=34550&start=0
read this thread from start to finish heaps.
viewtopic.php?f=5&t=52270
but there's heaps more.
PS welcome to the board.
Post Posted: Sat May 21, 2016 10:26 pm
31"s fit in the arch pretty easy, redrilling your spring perches to move your diff 20mm forward, big hammer, rim offset and some decent bumpstops will likely negate the need for much if any chop.
I run 32"s with only around 2" lift but i reckon i could easily drop that and still be ok.
.Image
Post Posted: Sun May 22, 2016 2:17 pm
that tyre is looking pretty tucked in there MrRocky - are you getting headlight bucket contact in that situation?
Post Posted: Sun May 22, 2016 8:04 pm
Nah i have given them a slight tap and they come very close but the stock lwb rear top spring seems to centralise the wheel perfectly in the wheel arch. Offset was super critical theres only a couple mm clearance in places, 50mm spacers in the rear and 35mm in the front, i tried a few other options but this is the only one that worked
Users browsing this forum: No registered users and 50 guests
