It is currently Sun Oct 11, 2026 12:02 pm
Post Posted: Mon Sep 21, 2009 9:21 pm
g'day all im abit of a newbie and was after some help. my sierra transfercase is making abit of a rattle when im not accelerating ( for example rolling down hills) and it slips out of 4h when going over bumps some times, are they easy to fix or better off buying a second hand one.
cheers
Vehicle: MY2019 Jimny
Post Posted: Mon Sep 21, 2009 9:56 pm
If it is rooted it would be easier to buy a second hand one with a 3 month warranty.
I'll buy your stuffed one if you go that way...
Post Posted: Mon Sep 21, 2009 10:05 pm
i got a price from a wreaker on a second hand one $550. i bit pricy i thought, could it just be the bearings have worn?
Post Posted: Mon Sep 21, 2009 10:13 pm
I got a price today $350 MINDEN wreckers but they dont have one :(
Post Posted: Mon Sep 21, 2009 10:59 pm
So why would thay give a price???
Post Posted: Mon Sep 21, 2009 11:02 pm
550 seems a bit steep.
even by perth standards.
Around $350 is pretty standard these days for a good second hand jobbie.
Post Posted: Mon Sep 21, 2009 11:23 pm
just wondering how much are the bearing kits?
Post Posted: Mon Sep 21, 2009 11:32 pm
Low Range Offroad
Post Posted: Tue Sep 22, 2009 1:37 am
are all the 1.3 cases interchangeable?
Post Posted: Tue Sep 22, 2009 1:51 am
Yes
Post Posted: Tue Sep 22, 2009 1:57 am
mine has the hand brake on the back of the case and the one im looking at doesn't so does the hand brake drum bolt onto the other case
Post Posted: Tue Sep 22, 2009 2:04 am
Should do, are the cases the same shape?
Some flange swapping may be in order...
Post Posted: Tue Sep 22, 2009 8:36 pm
they look the same shape, has anyone on here done this before that is swapped there nt transfer case with a wt transfer case
Post Posted: Tue Sep 22, 2009 10:31 pm
NT and WT cases are identical.
The NT handbrake drum will bolt onto the WT transfer and the NT flanges will go straight on as well.
Post Posted: Tue Sep 22, 2009 11:31 pm
ok cheers
Users browsing this forum: No registered users and 221 guests
