The SQ series rails are a hollow aluminum extrusion with cast feet that are assembled with some sort of adhesive that fails as it ages, I disassembled mine and drilled through the foot and the extrusion and fitted a screw & nut - BUT - if I had to do it over, I would just clean everything up and reassemble with some sort of silicone adhesive as the joint between the extrusion & the foot sits at an angle that is dictated by the curve of the roof.
Users browsing this forum: No registered users and 69 guests
