It is currently Sat Oct 03, 2026 10:47 am
Vehicle: 2020 Vitara Turbo
Post Posted: Mon Jun 13, 2016 7:21 am
Hey guys,
I'm chasing knowledge or a service manual for EGC31S Baleno. Is it the same pin outs on the ECU as the pack over plug coils or completely different with the stand alone coils please?
Thanks.
Pete.
Post Posted: Mon Jun 13, 2016 8:20 am
There are 3 -4 different pinout configurations within the baleno coilpack family of motors
Post Posted: Mon Jun 13, 2016 2:25 pm
Ok, so I've got one of the manuals at home, I should roughly be close to where I need to be? I'll trace it back. That's good then. Thanks for that Michael.
Pete.
Post Posted: Mon Jun 13, 2016 6:26 pm
There is only 2 igniton, 2 earths and fuel pump wire need connecting
Post Posted: Mon Jun 13, 2016 6:49 pm
Yeah i've done a few Vitara ones now, I'm just hoping the Baleno diagram I have already will be close enough to the one we have.
I've got a 4 coilpack one which i'm hoping is not too distant to the coil on plug.
Post Posted: Mon Jun 13, 2016 7:41 pm
U mean with a distributor ???
Post Posted: Mon Jun 13, 2016 7:47 pm
No distributor.
The coilpacks are at the end of the head, which will be moved to another location when it's in the Sierra.
Post Posted: Mon Jun 13, 2016 7:54 pm
Got a pic at all ?
Post Posted: Mon Jun 13, 2016 8:30 pm
coilpacks are mounted at the rear, which i'm happier about as i can get them away from the heatsoak in the sierra.
Post Posted: Mon Jun 13, 2016 8:41 pm
Wow thats unusual, im guessing an import.
Is it a 1.5 or a 1.6 ? Never even seen that vairiant in wa
Post Posted: Mon Jun 13, 2016 8:51 pm
all badging has g16b, compliance etc.
Engine number stamped on block is G16B-235207
Post Posted: Mon Jun 13, 2016 9:20 pm
Can u take a pic of the ecu sticker
Post Posted: Mon Jun 13, 2016 9:28 pm
Behind glovebox is that's anything different. it's a 1998 Baleno Mystique.
Has 1 daffodil sticker.
Post Posted: Tue Jun 14, 2016 8:20 am
AHUH!
There's your problem!
You are missing a daffodil sticker
Just hack out what you dont need, and transplant the rest.
Keep all the loom for reference and you will know where they all go and which ones are needed.
Post Posted: Tue Jun 14, 2016 10:35 am
Not unusual. There's 3 different baleno motors. Distributor at back of head, coil pack on back of head, and the coil on plug style which has the coil packs on the valve cover.
Post Posted: Tue Jun 14, 2016 10:52 am
These are the ecu i normally do the looms for
Im gunna say the coil at rear of head configuration would be less than 15% in balenos at least in west oz.
As long as you have the correct pinouts then you cant go wrong
Post Posted: Tue Jun 14, 2016 11:58 am
Cheers guys. Yeah I'll go through it on the weekend and start pulling out the harness and have a look. Got the Vitara ones down pat and I've written down the special pinouts, I've found 1 baleno pinouts so I'll just go from there.
Users browsing this forum: antantant, Google [Bot] and 176 guests
