It is currently Mon Sep 21, 2026 6:59 am
Vehicle: 2000 Suzuki Grand Vitara
Post Posted: Sun Jul 17, 2016 2:52 pm
Hi All.
As you would have noticed from all my posts Im new to the Sierra game even
though i do have a Grand Vitara.
I am mechanically minded and have always played around with cars. In trying to sort
out the interior light and the door switch's i discovered that previous owner have connected
the handbrake switch into the door switch / interior light at the loom.
I have now sorted the door switch / interior light but can't work out where the handbrake
cable should plug into at the loom under the dash.
Can someone please trace theirs and post some photos?
I have looked at wiring diagrams and they say orange but cant find any orange cables under the dash.
Thks in advance once again.
Chris.
Post Posted: Sun Jul 17, 2016 10:08 pm
Is there a brake fluid level switch on the master cylinder? That's usually where the handbrake switch ties in - the brake warning light on the dash illuminates if the fluid is low, or the handbrake up.
Post Posted: Sun Jul 17, 2016 10:56 pm
Will have a better look tomorrow but I think it links into the the brake fluid level switch (as fordem says) and the instrument cluster. Where exactly it connects in the harness if have to have a better look
Post Posted: Mon Jul 18, 2016 12:32 pm
Righto.. Without delving too far into it at the moment. The handbrake switch runs a black wire beneath the drivers seat and into the sill.
It appears to run backward in the sill but difficult to say for sure. Either way it connects under the dash just above the fusebox with a soft insulated connector, becoming a red wire with black tracer. I tried to get pic of it.
Does that help?
Post Posted: Mon Jul 18, 2016 5:37 pm
Great that helps a lot. Well check mine tomorrow.
This all for your help.
Chris
Users browsing this forum: Google [Bot] and 171 guests
