It is currently Tue Sep 29, 2026 12:04 am
Vehicle: 2006 2.7 prestige auto.
Post Posted: Fri Aug 05, 2016 2:34 pm
I finaly put my second hand iron man bash plates on my NGV again. They seem to be transfering quite a bit of noise to the cabin. It was much worse because the plates where touching the exhaust . I put a bit of a spacer in to seperate the plate from The exhaust. Is it normal to have an increase in cabin noise when you fit bash plates. Any advice on how to stop or reduce it further ?
Thanks
M
Post Posted: Fri Aug 05, 2016 2:43 pm
Yes, you'll get more noise, bit like changing from road tyres to mud tyres. No easy way to solve it, you are reflecting engine noise back into the cab, you could try putting more insulation under the carpet, turn up the volume on the radio or just wait, you'll get used to it..
Post Posted: Fri Aug 05, 2016 4:08 pm
Thanks Steve if it's a feature not a fault I will not worry.
Post Posted: Fri Aug 05, 2016 7:13 pm
I still have steves old bash plates here
Users browsing this forum: Google [Bot] and 149 guests
