It is currently Thu Aug 13, 2026 1:00 pm
Vehicle: Suzuki Grand Vitara
Post Posted: Sat Sep 03, 2016 1:12 pm
Hi all
I have just bought a 2001 Grand Vitara v6 and it needs new tyres, so I am looking at getting some AT tyres. I will be getting a 2" lift later on, i'm wondering what is the max size tyres that can be put on without a extra lift.
Thanks Steve
Post Posted: Sat Sep 03, 2016 10:06 pm
The 2" lift makes no difference to the maximum tyre size you can fit.
225 75 16's are common but require some hammering of seams and trimming of plastic.
Post Posted: Sun Sep 04, 2016 5:19 pm
Do you think 235/70/16 would fit too or will I need to do some hammering and trimming also.
Thanks
Post Posted: Mon Sep 05, 2016 3:55 pm
I went with 225/75/16
Thanks for the info.
Post Posted: Sat Oct 01, 2016 5:10 pm
How much hammering and trimming was required?
Post Posted: Sun Oct 02, 2016 1:47 pm
I only needed to trim the front plastic inner guard.
Post Posted: Sun Oct 02, 2016 2:10 pm
I suspect you haven't fully compressed the rear suspension yet. The old shape GV's I've seen on 225's all needed hammering of the rear guard lip and trimming of the plastics to prevent tyre damage/jettisoning of trim
Post Posted: Fri Oct 07, 2016 5:42 pm
It was fine in the rear, now i have a 3" lift front and back. So all good.
Post Posted: Sat Oct 08, 2016 8:58 am
So have you spaced the rear bumpstops?
Post Posted: Sat Oct 08, 2016 1:07 pm
No I haven't, what needs to be done.
Thanks
Post Posted: Sat Oct 08, 2016 2:05 pm
Thanks
If you have no scrubbing then nothing needs to be done
Post Posted: Sat Oct 08, 2016 6:59 pm
Thanks.
Post Posted: Sat Oct 08, 2016 7:15 pm
Except that will have scrubbing, you just haven't yet.
Post Posted: Sun Oct 09, 2016 9:01 am
I'll explain in a bit more detail.
If you have fitted longer springs to achieve the lift suspension lift, all you have done is move the rest point of the suspension when the car is static. When the car is in motion, the axle's movement is limited by the extended length of the shock absorber (droop) and the factory bumpstop (compression). This compressed position is the same as a standard car - the lift springs don't change it.
Lift springs can give the impression they allow larger tyres to fit because in "normal" (road) use the suspension only moves through a small range of travel, so the new rest position moves that working range up and away from the interference point.
However, when you fully flex the suspension off road, or you're carrying a heavy load, or you unexpectedly load the suspension hard (like go too fast over a drain on a track) the axle will reach the factory bumpstop and tyre contact will occur.
In the case of the GV, it will cut the rear tyres on the leading edge of the rear wheel arch, and catch the plastic sill trim, pulling it down and off the vehicle.
There is nothing different or unique about your setup - every GV with 225's I've seen requires clearancing to run a 225.
Post Posted: Sun Oct 09, 2016 5:32 pm
Ok have had car fully loaded but no scrubbing as yet, when you say space bumper stops what needs to be done.
Thanks.
Post Posted: Sun Oct 09, 2016 8:13 pm
take the rear springs out so the suspension fully compresses onto the bumpstops. trim/hammer as appropriate. If you d contact at the top of the rear guard excessive, space the bumpstops. ARB sell a bumpstop spacer for the front of an XL-7 which I believe will work in the rear of your GV. I believe regardless of bumpstop spacing, you'll still have some contact at the leading edge of the rear guard.
Also consider getting the chassis up on jack stands and fully compressing one side only with a floor jack whilst the other is at full droop (rear shock fully extended) - the compressed tyre will move up further in this scenario, but because it tucks in away from the guard lip contact isn't often as bad.
You've fitted substantially larger tyres than standard - this is the normal process to go to when you've done this. As I've said, better to go through the process now rather than hit a big bump offroad and cut the tyres/remove the sill trim.
Post Posted: Mon Oct 10, 2016 4:24 pm
I will take a look and do it anyway better to be safe than sorry. Thanks for the info.
Thanks
Vehicle: Suzuki Grand Vitara 04 manual
Post Posted: Fri Oct 28, 2016 4:04 pm
Are There any additions to the above info to install 235/70/16? Guards Already removed and mud guard trims pushed back.
Post Posted: Sun Nov 20, 2016 11:13 am
If you have access to an RTI style ramp could you use this to determine the travel and clearance for each wheel/tyre? Would be easier than finding 4 jack stands and removing the springs. Then when on the ramp measure the clearance at each wheel arch minimum gap to determine how much bigger you can go before needing to change suspension?
Users browsing this forum: No registered users and 55 guests
