It is currently Thu Oct 01, 2026 12:08 am
Post Posted: Sat Nov 12, 2016 1:25 pm
Does anyone have a pic where the rib on the soft top clips into the top of the windscreen?
Phuck Photobucket
Post Posted: Sat Nov 12, 2016 1:28 pm
Should be a plastic strip that screws onto the top of the windscreen then the rib folds over it and into the clip/strip?
Will take a pic when I get home of someone hasn't already
Post Posted: Sat Nov 12, 2016 1:52 pm
Thanks
Phuck Photobucket
Post Posted: Sat Nov 12, 2016 7:26 pm
Dismantled one.
This strip goes on the top of the windscreen frame. The soft top curls over the top and fits into the C channel on the strip
Roughly where it sits on top of the windscreen frame
Secures right along the top with screws
Fits on the front (leading edge) top facing forward
Post Posted: Sat Nov 12, 2016 8:44 pm
Sweet. Thanks for that now I just have to hunt one down
Phuck Photobucket
Post Posted: Sat Nov 12, 2016 9:23 pm
You can buy them new from Suzistore, not too dear from memory. Being plastic and given the age of the poor old girls and where they sit, being brittle is sometimes a problem with 2nd hand ones.
www.bulldogtrimming.com
Post Posted: Sat Nov 12, 2016 9:46 pm
That's sounding even better ;)
Phuck Photobucket
Post Posted: Sat Nov 12, 2016 10:37 pm
Good tip - loosen off the screws on the channel a bit, fit the soft top strip inside (soft top draping over the bonnet), then tighten the screws, flip the top over and fit as normal. You'll get a nice even fitment and a good clamp down on the top. Then, check the front corners to make sure the top is as centered as possible. Add a glob of sikaflex / silicone to the exposed corners to stop water ingress at speed whilst raining. (ie: 80+km/hr in the rain water gets forced into the corners and inside). There should also be rubber corner bits on the window frame to help in avoiding this (not pictured above).
Post Posted: Sun Nov 13, 2016 8:19 am
Good advice Alien and just brought one from Suzistore thanks Benchai
Phuck Photobucket
Users browsing this forum: Google [Bot] and 192 guests
