It is currently Sat Jul 25, 2026 10:48 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page 1, 2  Next
Post Posted: Thu Sep 24, 2009 9:48 pm
Hi All,
I'm after some seats to replace my fronts. What cheaper alternatives are there to race/sporty seats?? What have you guys used instead?
Rusho
Post Posted: Thu Sep 24, 2009 9:52 pm
I used Swift GTi seats, cost me $200
Post Posted: Thu Sep 24, 2009 9:53 pm
Rusho81 wrote:
Hi All,
Rusho
Mate just go down to your local jap parts importer. Most jap sports cars have good seats in them. RX7's, MX5, Integras, WRX, supras etc all donate very nice seats to the cause :D
Also look at your sports saloons like the Stagea, and chasers etc.
Stock will vary, so you may have to stay on the hunt for a while.
Pete
Post Posted: Thu Sep 24, 2009 9:56 pm
Scrawny did they just 'bolt in' or did you have some minor adjustments?
Post Posted: Thu Sep 24, 2009 9:57 pm
They are the same width but slightly longer. Not hard to do.
Vehicle: MY2019 Jimny
Post Posted: Thu Sep 24, 2009 10:39 pm
92 Liberty seats will not fit.
Post Posted: Thu Sep 24, 2009 10:49 pm
LOL :D
Post Posted: Thu Sep 24, 2009 11:11 pm
autotechnica sports seat fit bolt in passenger side and made some spacers for the drivers side out of 50x10flat bar very comfy :D
Post Posted: Thu Sep 24, 2009 11:43 pm
my LWB has surf seats. they are shit.
Post Posted: Fri Sep 25, 2009 1:05 am
HA HA HA Toyota parts in your suzi :lol: and post number 2000 you post whore
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Post Posted: Fri Sep 25, 2009 1:11 am
HOLY CRAP!!!!!!!!!!!!!!!! :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :finger:
Post Posted: Fri Sep 25, 2009 1:14 am
You can't talk, another month and you will have caught him :P
Post Posted: Fri Sep 25, 2009 1:45 am
2.5 years for me.
6 months for steknig. :D
Post Posted: Fri Sep 25, 2009 1:50 am
it is damo's fault. i have been trying to get him to reset the counter but he wont do it. :cry:
it is a bit embarrassing. maybe i need to go fishing.
Post Posted: Fri Sep 25, 2009 1:56 am
2.5 years for me.
You have a life, I`m just a dickhead.
Can i come fishing????
Post Posted: Fri Sep 25, 2009 2:06 am
steknig wrote:
2.5 years for me.
mate i will go fishing with anyone. have ya seen the thread for next julys trip :wink:
Post Posted: Fri Sep 25, 2009 2:13 am
Yess, & very tempting, I`m doing the cape run next year so I`ve gota save for that.
But your place is only round the corner from bris, I may drop in for it..
GV`s love the highway, cruise on 130-140 all day.
Post Posted: Fri Sep 25, 2009 2:41 am
and those speeds are legal here :wink:
Post Posted: Fri Sep 25, 2009 2:45 am
I better get bigger injector`s then so I can sit on 190 !!!! 8)
Post Posted: Fri Sep 25, 2009 3:48 am
i put some autotechnica seats in my old sierra- i did the dodgy and mounted the universal rails directly to the stock rails. The holes line up perfectly, you may find that the shoulders of the seats stop the seatbelts from retracting. Id recommend the GTI seats, they look easy to get in/out of, bucket seats can be a pain
Post Posted: Fri Sep 25, 2009 2:55 pm
I recently put in some cheap autotechnica racing style seats the i got from repco. Cost 300 for the 2. ADR approved. Same bolt width just needed to drill two new holes for the drivers side in the existing rails. Only just in the car though.
Post Posted: Fri Sep 25, 2009 9:06 pm
would the normal swift seats fit none gti ?
Post Posted: Fri Sep 25, 2009 9:41 pm
will with the same mods as a gti seat :D
Post Posted: Sat Sep 26, 2009 10:15 pm
fitted my gti mk3 seats this arvo.. took a couple of hours if that...
a little dicking around but all in all a pretty easy fit.
Web wheeler extroadinaire
Post Posted: Sat Sep 26, 2009 10:37 pm
Post a couple of pics for me please
Vehicle: SJ80, SE416
Post Posted: Sat Sep 26, 2009 11:47 pm
In a coily (as opposed to a wt/nt), you need to do a fair bit more to fit aftermarket seats. The rails are side mount type, not top mount, so you will need to muck about with the rails a bit more.
The inside rails sit 20-25mm higher then the outside ones also. I cut down the rails a bit so they are the same height and used 450mm long 50x75x5 angle bolted to the cut down factory rails to give me a surface to mount the seats to. I drilled the angle and used existing bolt holes in the coily seat rails and M8 HT bolts and the factory 7/16 UNF bolts. I needed to extend the seat belt clip bolt, - it is now a 1 1/2" 7/16 UNF, instead of the 3/4"? one.
For my Autotechnica Monza seats, I needed to add 2x 425mm long 50x8 flat bar running perpendicular to the angle rails and used the supplied M8 hardware to mount the seats to these bars and 2x M8 bolts per seat corner to attach the bars to my rails. The only reason I needed these additional bars was because the mounting centres were 390mm apart, and the factory rails are 385mm apart and I wanted the seat bolts to sit virtually on top of the uprights on my angle. I needed to notch the angle a bit as well.
These seats sit a bit higher up then the lower slung side mount coily seats (about 2"), but I also prefer this driving position in a 4x4. Another thing to mention is the factory rails appeared to be stronger then the rails (to suit patrol?) that I had supplied with the seats.
Post Posted: Sun Sep 27, 2009 12:18 am
Thanks for that Reubs. If you get a chance mate could you throw on a few pics. Cheers
Post Posted: Thu Oct 01, 2009 3:02 am
thought i better add to this post as ive just replaced the seats in the sierra.
A good mate gave me some leather seats from the back of a chrylsler voyager. they are bucket seats and were such an easy swap. All I had to do was oval the existing seat mounts to get the zook rails to bolt up. These are a very wide seat and have armrests that fold down . will post a pic later when i get some during daylight.
B4t
Hmm leather seats :roll: :roll:
Post Posted: Thu Oct 01, 2009 5:12 am
geez sounds a bit classy B4T.. :)
i just installed some autotechnicas.. wont be as comfy as yours ill bet but they are a snug fit so no slopping sideways when i flop it on its side next time :)
Post Posted: Thu Oct 01, 2009 1:40 pm
gti mk3
Users browsing this forum: Google [Bot] and 401 guests
