[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Racingsteve
Vehicle: Suzuki Grand Vitara
 Posted: Thu Jan 05, 2017 2:59 pm |
Where do people buy there coil packs from and I'm after a clutch fan center for a 1999 grand vitara I'm in Brisbane I'm chasing a rough Idle issue just replaced plugs and one of the coil packs Seems to problem so rang around and just about fell of chair $200 eBay it seem a lot cheaper any brand worth chasing And where to buy Cheers Steve
30ONA
Vehicle: Suzuki Grand Vitara 04 manual
 Posted: Thu Jan 05, 2017 6:38 pm |
Got mine from rock auto us. Very well priced. I still have my 4 old coils that were working you can borrow them to see if it fixes the problem.have you inspected them or resistance tested them?
I'm also in need of a clutch fan if you want to share postage.
got_bar_work
Joined: Sat May 15, 2010 8:30 pm Posts: 2214 Location: Brisbane
 Posted: Thu Jan 05, 2017 8:46 pm |
Do u need a new fan or do u need to just add new grease
Racingsteve
 Posted: Thu Jan 05, 2017 9:44 pm |
No haven't checked resistance yet just got on new one up at repco replaced it made no difference after spraying some wd40 around I think one of the injectors are leaking the rear one seems to be sucking the spray in or out but no petrol leak . Now I'm wondering if there's some kind of kit for the injector I'm sure there is but where to buy, looks like it may have go to a Mechanic it just a bit past my know how, unless someone here can suggest something simple to fix cheers Steve
30ONA
 Posted: Fri Jan 06, 2017 5:21 am |
I would suggest if you are in Brisbane get in touch with dr Suzuki. Dave. He will be able to help. Look in the business directory section. viewtopic.php?f=15&t=53437
ZUZUKI
Joined: Thu Sep 02, 2010 5:50 am Posts: 427 Location: Melbourne
 Posted: Wed Jan 11, 2017 11:35 pm |
You don't say if it is a V6, but regardless, injectors are a bit of a pain to get at / remove & you might as well have them sonically cleaned while you've got them out, which is a trip to a workshop with the equipment anyway. They would / should have the correct o-rings & caps in stock anyway. Rgs, Michael
30ONA
 Posted: Thu Jan 12, 2017 7:04 am |
EIS injector services are good. Will come to you, remove clean and reinstall.
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 140 guests
