It is currently Fri Oct 30, 2026 3:49 am
Vehicle: Suzuki Grand Vitara 04 manual
Post Posted: Sun Jan 22, 2017 3:21 pm
Not tested out yet. I think it may need some stiffening through the middle, but should be ok for light items. Total cost $64.
trying to get photos to wrk.
Post Posted: Sun Jan 22, 2017 3:53 pm
[/url]Image[/URL]
Didn't' realise there was only 6 wingnuts in the packet. Will need to get some more.
[url=http://s1383.photobucket.com/user/Max_Willison/media/IMG_20170122_144837_zpstagvz7sd.jpg.html]Image
Vehicle: Jimny Sierra 2006 M13A
Post Posted: Sun Jan 22, 2017 10:24 pm
I had a mate make one out of the same security screens, however bent the edges to a 80mm lip 45 degree cut the edges and then put the edging on and weld it shut - like a proper basket.
Two lateral stringers were run down the rough the guts for added stability and strengthening for the U shackles.
Vehicle: zook
Post Posted: Mon Jan 23, 2017 10:01 am
Form follows function Armsup
The alloy roof rack I made for my GV was similar but I used uncoated security mesh and welded it into a 25mm tube frame. The idea was to keep as low profile as possible but I found the mesh to be incredibly draggy.
YMMV.
Post Posted: Mon Jan 23, 2017 3:24 pm
YMMV.
This will only be installed on an as required basis, removed all other times.
Post Posted: Mon Jan 23, 2017 3:27 pm
I'm thinking some very small section alloy SHS, riveted on from underneath to stiffen it up in the middle.
Post Posted: Wed Jan 25, 2017 6:11 am
I moved the mounting position forward as there is a slight curve on the rails, this partially pretensions the tray up. Also fitted a stiffening bar for $5.95. Total cost now a whopping $70.
Users browsing this forum: No registered users and 20 guests
