It is currently Sat Oct 31, 2026 11:10 pm
Vehicle: Sierra g16 efi..and Sierra GTi
Post Posted: Sat Feb 11, 2017 4:45 pm
Someone asked after seeing the Bikini tops I have made, if I would make them a Bimini roof... How hard can it be.. I had to patch a hole in the guys old roof first but I think it all turned out well....
PS....Josh...you roof is ready .....
Here are a couple of the Bikini tops on 2 of our Zooks..
Post Posted: Sat Feb 11, 2017 5:19 pm
cool, I like the bimini over the bikini, just need one for a lwb (hint).
Post Posted: Sat Feb 11, 2017 5:49 pm
I would be a bit concerned about the "flapping" in a LWB... How much longer are they than a SWB ???? It may need some sort of side frame to support it.. That wouldn't be that difficult to make and the sides could clip onto the frame...
Post Posted: Sun Feb 12, 2017 12:54 am
You could use the LWB soft top bars. Would work great :)
In the pic you can see the rear bar but there's a mid section bar too
Post Posted: Sun Feb 12, 2017 12:27 pm
Hmmmm ...Is this an original lwb soft top . If so I can see the center bar.. If they have roll up sides and roll up rear window, there would not be much point in destroying one to make a Bimini top as it is almost one already but with the advantage of dropping the sides etc if the rain started..
https://www.google.com.au/search?q=lwb+ ... 3jYDg15g2M:
Post Posted: Sun Feb 12, 2017 5:11 pm
Ah righto!! I thought you were making them from scratch rather than dissecting a softy for it..
But either way if you had one that deserved a good dissection then the LWB bars would keep it Mickey Mouse or flapless :)
Post Posted: Sun Feb 12, 2017 9:04 pm
Yes..Sorry, I am not making them from scratch.. I am simply turning old or faulty roofs into modified roofs..As long as it is in reasonable condition, it could easily turn into a Bimini however without a LWB Sierra to test fit it onto it may be a bit tricky. The one i just Moded was on and off the car 3 times.. One to do some chalk markings, the second to see how it was and if it needed any strengthening and a final fitting to make sure I was happy with it..
Post Posted: Mon Feb 13, 2017 6:30 am
Compared to the daggy top I gave you missing the rear window, I'm stoked with the result! Thanks again mate 8)
Post Posted: Mon Feb 13, 2017 3:57 pm
No worries.. Text me when you want to come and get it.. The boys take the rexs up Mt Glorious at night occasionally ,maybe they could meet you somewhere..Are you a night owl as they go up quite late..11ish or later...no traffic up there then..
Users browsing this forum: No registered users and 40 guests
