It is currently Wed Sep 23, 2026 10:58 am
Vehicle: Suzuki Grand Vitara 04 manual
Post Posted: Sat Apr 29, 2017 3:03 pm
This is new since last weekend. Is this acv boot failure or something worse?
Post Posted: Sat Apr 29, 2017 10:33 pm
Take your finger and separate the pleats of the boot whilst you slowly rotate the wheel - if the boot is torn or punctured you'll find out soon enough...
Post Posted: Sun Apr 30, 2017 8:13 am
O yeah it's torn and grease coming out. But is it normal for there to be grease everywhere inside.I just always assumed the cv was a bit more like a sealed bearing and the cover was more like a dust cover than a grease seal.
Post Posted: Sun Apr 30, 2017 8:39 am
It's a grease seal. What you're seeing is normal
Post Posted: Sun Apr 30, 2017 10:26 am
The boot does both - it keeps the grease inside the joint and the dirt outside - if the boot gets a tiny hole, the centrifugal force will the grease everywhere - the inside of the rim, the wheel arch, literally everything gets grease.
Post Posted: Sun Apr 30, 2017 8:02 pm
Can you replace them without dismantling?
Post Posted: Sun Apr 30, 2017 8:30 pm
No. Has to come apart.
Users browsing this forum: No registered users and 56 guests
