It is currently Thu Nov 05, 2026 4:20 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 18 posts ]
Vehicle: 2003 SQ625 Auto
Post Posted: Fri Apr 14, 2017 3:33 pm
Top
03 GV 2.5lV6 auto wrecking Sunshine Coast QLD JML steel winch bar, wheels tyres etc
My car has an issue with ECU (probably got wet from A/C drain blocked) and I do not have the time or inclination to fix it, general consensus is it would need a replacement ECU, immobiliser and key.
there are a few good bits on it that people might find useful :
2.5l V6 engine (Engine ran well with plenty of grunt until the ECU died)
Auto gearbox with transmission cooler,
JML steel winch bar (but no winch fitted),
Cibie Oscar plus driving lights (reflector in 1 isn’t good but it still works),
A full set of 5 x Goodyear Wrangler AT/Silent Armor 235/70/R16, with approx 60% tread, on steel GV wheels.
another full set of 5x standard size HT tyres on steel GV wheels.
Dobinson struts,shocks,springs (approx 40mm lift),
plus a full spare set of ironman struts,shocks, springs (approx 30mm lift not currently fitted),
recently replaced lower wishbones on front suspension,
recently replaced front axle oil seal and bush to locate driveshaft,
recently replaced driveshaft boots,
flip down table on rear tailgate made from typeX switchboard panel (very stiff),
Hoping someone might want the entire car to source bits from, if no takers within a couple of weeks, will separate parts if necessary.
Please P.M. me (so I get a notification email that you’re interested).
Regards
GV6
Post Posted: Fri Apr 14, 2017 5:44 pm
Top
Got an idea on prices?
Post Posted: Fri Apr 14, 2017 6:37 pm
Top
Hoping to get $1400 for whole lot, or might consider separating parts if no takers.
Forgot to mention it has polyair air bag helpers in the back too.
Post Posted: Fri Apr 14, 2017 8:14 pm
Top
Can I have first dibs on the bar please if you end up separating??
Vehicle: Suzuki Grand Vitara 04 manual
Post Posted: Sun Apr 16, 2017 4:40 pm
Top
What's the price for a set of struts/shocks? Are the iron man ones new?
Post Posted: Mon Apr 17, 2017 1:25 pm
Top
Update : I got some time to look at car over Easter, everything else checked OK, ended up pulling the ECU to pieces which positively confirmed that the ECU's electronics had corroded badly due to water ingress. To get it going you would definitely need a replacement ECU, numbers on ECU are : 33920-52J5, 1, 052J5, 2.5 E24 $AT 03MY, GQ, PCMSB-880A, A1, 4601, Hitachi.
Will let you know if i end up separating the main car.
Ironman shocks/struts aren't new they were on the car for about 14 months, before I changed to a Dobinson kit looking for more front lift. Turns out I needed spring spacers on the Dob's as well to get the front sitting where I wanted it.
Ironman struts / shocks would be $250 for the set, Ironman Springs would be $50 for the set.
Powdercoating has come off front coils (of both Dob & ironman) which looks unsitely but doesn't affect performance in the short term.
Ironman Struts / shocks are still in good condition.
Post Posted: Mon Apr 17, 2017 2:47 pm
Top
If you can hold for me till next month ( monthly pay sucks) I'll take the iron man gear shocks and springs. From your posts they are not on the car so are available separate.
Post Posted: Mon Apr 17, 2017 4:09 pm
Top
Also on the car itself how many k's?
Post Posted: Mon Apr 17, 2017 4:46 pm
Top
Interested in a set of rims if you'll sell separately. (Don't particularly need tyres) got a price?
Post Posted: Mon Apr 17, 2017 8:55 pm
Top
Car is 200,010 km.
Post Posted: Mon Apr 17, 2017 9:21 pm
Top
One set of wheels with HT tyres might be gone......... will let you know if that falls through or if I end up separating bits on car due to no takers for whole car.
I'll probably give it till sometime next month to decide whether bits on the car get separated.
I'll hold the ironman shocks/struts for you till next month.
Vehicle: suzuki Grand Vitara
Post Posted: Tue Apr 18, 2017 7:04 am
Top
If you separate I will take the dash stereo surround if it's in one piece
Sent from my A1601 using Tapatalk
Post Posted: Fri May 12, 2017 6:35 pm
Top
some pictures available here :
https://www.gumtree.com.au/s-ad/coolum- ... 12?ref=ais
Vehicle: Suzukiless these days..
Post Posted: Sat May 13, 2017 9:53 pm
Top
Were on the Sunshine Coast?
goddamitmyspacebarsbrokenagain
Post Posted: Mon May 15, 2017 1:50 pm
Top
Coolum 4573.
Will let you know if it gets separated.
Vehicle: 6.5s, gti, 31 extremes
Post Posted: Tue May 16, 2017 6:25 pm
Top
I'm keen on some stuff if you part it. Pm me if you do
Twincam coiler, rocktoy, 6.5s, lift, 31 extremes
Post Posted: Tue May 23, 2017 1:14 pm
Top
UPDATE : SOLD entire car today.
The only thing left is a full set of 5x steel GV wheels with 235/60R16 HT tyres 50% worn. $300, pick up only (from Coolum Beach QLD).
Please P.M. if interested in wheels / tyres.
Post Posted: Tue Jun 06, 2017 10:09 pm
Top
Update : Wheels SOLD, all gone.
Regards
GV6
Users browsing this forum: No registered users and 29 guests
