It is currently Fri Nov 13, 2026 1:06 pm
Post new topic Reply to topic  [ 553 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 19  Next
Post Posted: Sun Jul 03, 2016 7:26 am
20zook15 wrote:
unexpected need for some more space has arisen!
I think that's a common reason for it
Vehicle: Jimny 1800 2009
Post Posted: Sun Jan 08, 2017 3:00 am
Just some feedback on my M18 conversion. Did the conversion at 110000 km.
Odo meter now at 205000 km. So 55000 km done. No gearbox, transfer case and diff problems.
I also do not drive like grandma going to church. Done some serious off road stuff like a recent 5000 km trip in Mozambique.
I now fitted a ARB rear diff lock. I replaced the crown wheel and pinion just to be on the save side.
To my surprise, the original diff shows no obvious sighs of wear. The back lash seems to be very little and is about the same as in a new Jimny.
So this is my 2 cents worth of info. May it give some Mates peaceful sleep. :D :D
Post Posted: Mon Jan 09, 2017 6:53 am
I've also done 50,000 with my 1.8 and no driveline problems
Post Posted: Mon Jan 09, 2017 12:46 pm
To be fair Muscle, there are too many other variables to use your experience to put anyone's mind at rest. I've seen plenty of Jimny driveline failures with g13 and m13 engines.
Post Posted: Tue Jan 10, 2017 1:56 pm
You seem to hang out with people who are great at breaking Jimnys.
Post Posted: Tue Jan 10, 2017 5:36 pm
I can only report what I see. I've never seen one driven hard either.
Post Posted: Wed Jan 11, 2017 6:46 am
As Muscle was doing
Post Posted: Wed Jan 11, 2017 7:29 am
I think sample size is also important. I've seen many jimny's over many years.
Post Posted: Wed Jan 11, 2017 11:31 am
Living with one is better sampling than observation.
By the way I know you are Steve, it's in your user name so no need for signing off.
Post Posted: Wed Jan 11, 2017 12:51 pm
Do you want to think about that a bit more? That makes no sense.
I'm 5'7" tall. Therefore I can say without further observations, from my experience of my sample size, that all men must be 5'7" tall.
Likewise, I could have lived with a jimny for a few years and broken nothing, that doesn't make my opinion superior someone who has observed many Jimny's being driven off road since they were launched, unless you wanted to find that Jimny's don't break.
Post Posted: Wed Jan 11, 2017 1:09 pm
Me: Big long reply.. blah blah blah... Delete delete delete. LOL Not worth continuing and wrecking a perfectly good tech thread
Vehicle: 91 Tin Top
Post Posted: Wed Jan 11, 2017 1:21 pm
Wise choice.
This was the last guy that tried to convince Steve that not every single part on a Jimny is made of glass..... :wink:
Post Posted: Wed Jan 11, 2017 1:27 pm
And I wasn't trying to wreck anything. I was only challenging the idea that one person's experience with very little other information should put people's mind at rest. I think the whole reason we're on these forums is to learn from a broad base of experience.
In relation to jimny's driveline being made of glass, It would take a bit to turn that opinion around, but I wil provide some expansion. "When used for touring, or driven the same places and in the same manner as a comparibly equipped sierra, a jimny's driveline appears to be made of glass, from my observations and experience"
There.
Vehicle: LJ50V 2 stroke
Post Posted: Wed Jan 11, 2017 1:34 pm
I broke more driveline part in my Jimny than there were replacement parts in Victoria at one point.
and this was over ten years ago, when everything had less wear than it does now.
Post Posted: Wed Jan 11, 2017 2:38 pm
Me: Start of long reply... Delete delete delete. OOPS! I did it again. :rofl: :rofl:
Yet you continue.
Post Posted: Wed Jan 11, 2017 2:39 pm
pete_79 wrote:
Wise choice.
:lol:
Vehicle: Jimny
Post Posted: Sun Jan 29, 2017 5:32 am
Great thread! Just a pity the pics are missing from post 1.
My M16A engine arrives next week and next weekend I will be fitting. Looking forward to the strip and transplant. Thanks to all who contributed here!
2009 Zook Jimny Sport
2inch Jimnybits lift kit
AVO adjustable shocks
Adjustable panhard rods
235/75r15 Kumho KL51
Ex: 2010 Suk Grand Vitara
Ex: Toyota Yaris TS
Build Thread: http://www.4x4community.co.za/forum/...ead?highlight=
Vehicle: Suzuki Jimny
Post Posted: Sun Jan 29, 2017 7:59 pm
Gwagon if you keep filling tech threads with pointless dribble you will be joining hillbilly in the moderated list
hillbilly 2 wrote:
And this ^^^^ clown is why auszookers will never be taken seriously
Vehicle: Jimny
Post Posted: Tue Feb 14, 2017 12:51 am
Some information to update post 1.
I have just finished putting in the M16A directly out of the Swift Sport. There are a number of things you need to do different from the rest of the M series motors.
You have to use the M13A head on the M16A block, due to the M16A head not having the EGR valve. The ports are physically not in the head. I used the complete m13a head. Not sure what the difference is with the cams, but the intake and exhaust valves are exactly the same size. Howver, the intake and exhaust ports on the m13a head are bigger. This doesn't mean more power is going to be made, but its something to investigate.
Then the shower stopper...on all other M series engines, except the swift sport m16a, the timing gear on the crank is the same. To get the m16a to run on the m13a ecu, you need to swap this gear from the m13a crank to the m16a crank.
Simple as that.
Fired up on the first crank and running well, however there is some pinging. My jimny is currently at the exhaust shop for a full branch and 57mm exhaust, following that it will go to the tuner for a chip to adjust fueling and timing.
Ex: Toyota Yaris TS
Post Posted: Fri Feb 17, 2017 6:58 am
That's interesting about the EGR ports, haven't heard this before. I know a couple of people running the 1.6 Sport but I'm pretty sure they didn't swap heads.
Keen to hear more about how you go with chipping it.
Post Posted: Fri Feb 17, 2017 8:40 am
i sure as hell wouldnt be swapping heads at the possible detriment of power to gain an egr valve that most people want to get rid of.
Vehicle: On the lookout
Post Posted: Fri Feb 17, 2017 3:36 pm
The Free image hosting website I was using has flipped to a pay service. I'll see if I can find the pictures again...
Crispy old grand vitara
Vehicle: Jimny
Post Posted: Mon Feb 20, 2017 6:40 am
Thx Squibby. Pics would be great.
@tanshi, that's a debatable point. The Swift rally car used the m13a head, so there must be something good about it. I don't have all the tech details, but I know that as the motor is now it is a massive improvement ove rthe m13a. To be able to spin 235/75/15 tires and generate some smoke is enough power in my eyes. Having said that, I have access to m13a and m16a cams now and will see if I can figure out if there is a difference. The cams are actually marked witha code, and even the same year engines sometimes have different codes. Whether this has to do with different cam profiles or just bearing clearances, I don't know. I chatted with my tuner, and the one thing the chip is not able to remove is the EGR error that pops up.
@ZukeNutter, I will check for pics, but I cant recall if I took pics of the heads side by side. What I do know is that the m13a intake and exhaust ports are bigger, by some 5mm per port. The valves are exactly the same size. As mentioned above, I am not certain of cam specs. Chip is being installed and tuned on Thursday and then I will have more detail. What I do know is that it is running rich, if my AF gauge is working. It was bouncing around at about 10.5 AF on idle.
Exciting times!
Ex: Toyota Yaris TS
Vehicle: suzuki sierra
Post Posted: Sat Jun 10, 2017 7:23 am
will m15a non vvt manual motor from a holden cruze fit onto a automatic m13a 2003 jimny non vvt?
thanks
david
Vehicle: stock
Post Posted: Sun Jun 11, 2017 2:14 am
Yes no difference in auto or manual
Post Posted: Thu Jul 27, 2017 3:12 pm
Some info to update Rivars' post
My Exhaust port was larger by 5mm, but Intake port, exactly the same.
This "timing gear" is a "sensor plate".
It is inside the block on the crankshaft and fires the crank angle sensor, as opposed to the "timing sprocket" which lives on the crankshaft outside the block and drives the chain and camshafts.
Awesome thread and great engine conversion.
Vehicle: Jimny
Post Posted: Wed Aug 30, 2017 11:53 pm
Glad you came right Barry.
I think I mentioned it in the private message, that the m16 cams have bigger lift and duration than the m13.
1.5mm on intake and 1mm on exhaust. The exhaust came is a direct drop in. The intake needs a bit of fine tuning...
On the end of the m16 intake cam is another tooth gear for the cam angel sensor pickup. This needs to be swapped from the m13 cam... Then when doing timing, the cam has to be retarded by 1 tooth on the timing marks to work...
My final dyno figures are 85kw and 145nm at flywheel.
Ex: Toyota Yaris TS
Vehicle: subaru
Post Posted: Sat Sep 16, 2017 9:03 pm
Has anybody considered doing an engine swap with a diesel? They came out as standard in Europe.
Post Posted: Sun Sep 17, 2017 8:49 am
The Diesel Jimny in Europe is made in Spain by Santana. It uses a 1.5 renault (?) diesel.
They're no great thing, being a cheaply engineered car that exists just because of the cheaper diesel price in Europe. It doesn't exist because it's awesome.
The Renault engine and its appropriate gearbox isn't readily available here. Every time this comes up someone links the ACME adapter for the VW TDi engine, which also isn't readily available here, doesn't really fit in a RHD application, (and wasn't designed for a Jimny anyway)
If you wish to pursue this further, in my opinion you'd want to start with a very early Jimny (G engine, lever shift transfer, no immobiliser, no ECU involvement in transfer shifting etc, and import a 1.9 TDI VW motor with a mechanical pump.
You'd also want an overdrive gearbox, not the Jimny gearbox with a direct 5th, because early Jimny's rev far too high at 100km/h to work with a diesel.
consider also that most laden jimny's with a front bar and/or dual batteries and/or a winch already take the front axle over maximum weight. roughly doubling the weight of the engine (and perhaps gearbox) will play havoc with the front axle housing and radius arms.
Vehicle: subaru
Post Posted: Sun Sep 17, 2017 9:44 pm
Thanks for all the info. I didn't know much about the European version only that they made one. I thought the diesel option for Oz would be better than petrol.thanks again. Cheers
Users browsing this forum: No registered users and 67 guests
