It is currently Wed Sep 23, 2026 7:48 am
Vehicle: Vitara
Post Posted: Sat Jun 24, 2017 6:41 am
Hey people Im new to vitaras I use to own a Sierra loved it.
Can somebody tell me the model, years and engine of the vitaras with steel diffs please?
And these diffs do they bolt in all the vitaras
Im thinking about getting a 2002 2.0 litre gv
Or a sv620 auto v6.
Post Posted: Sun Jun 25, 2017 5:57 am
Steel diffs were only fitted to the manual transmission 2.5 litre Grand Vitaras (98~05) and the early XL-7s (upto 2003), they can be fitted to any of the Vitaras, provided you use the matching center mount.
Post Posted: Sun Jun 25, 2017 10:18 am
also consider that the ratio won't necessarily be compatible, so you will need to swap that (or swap to 5.12 of offset larger tyres) , and the steel diff cars also have 26 spline front axles and axle disconnect.
Regardless, I'd also invest in the stubby shaft modification to prevent the RHS axle falling out
Post Posted: Sun Jun 25, 2017 4:54 pm
My 2003 auto gv had a steel front.
Post Posted: Sun Jun 25, 2017 5:10 pm
Pretty sure that's unusual.
Vehicle: Which one?
Post Posted: Mon Jun 26, 2017 12:37 pm
I was under the impression that the 2003-2005 (late gen1 GV, with the updated dash) autos had the steel front diff. At least, all of the ones I saw had them. Not that I saw many.
Post Posted: Mon Jun 26, 2017 3:23 pm
^^^ this
Vehicle: Suzuki Grand Vitara 04 manual
Post Posted: Mon Jun 26, 2017 4:45 pm
What are the they if not steel, cast alloy? I'm assuming only referring the the case
Vehicle: zook
Post Posted: Mon Jun 26, 2017 4:51 pm
cast alloy casing is correct
Post Posted: Mon Jun 26, 2017 5:27 pm
Third member (sometimes referred to as the carrier) and housing.
Users browsing this forum: No registered users and 37 guests
