It is currently Sun Sep 20, 2026 7:45 pm
Board index » Talking About Stuff » Shep's Jeep Corner
Post new topic Reply to topic  [ 207 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
Vehicle: Vitara 1994
Post Posted: Thu Mar 30, 2017 2:37 pm
Narh nothing broken, just welded up a new exhaust and started plumbing up the second fuel tank.
I thought about the A pillar mounted lights but I can't stand reflected light from bonnet or aerials. Jeep will end up with a uhf and a vhf radios when I get around to fitting them.
Fixed the lack of lights by stealing the HIDs off my wife's car, hopefully she doesn't notice haha
Reflected light does suck. Good work on the fix
Post Posted: Sun Apr 16, 2017 6:56 pm
I couldn't get the HIDs to work properly so just did what everyone else does and bolted a light bar on.
Drove a few 100km last night and it worked ok but would like a bit more distance.
Still very happy with the car and no issues except that I need a bit more belly height.
Vehicle: 91 Tin Top
Post Posted: Mon Apr 17, 2017 7:36 am
Looking good. No disconnects yet???
http://www.doubleblackoffroad.com/jeep-wrangler-parts/Teraflex-Front-Swaybar-Disconnects-0-3--Lift.aspx
Post Posted: Mon Apr 17, 2017 8:21 am
It doesn't seem to mind the lack of articulation, as long as one wheel is on the ground it seems to keep moving forward.
The traction control works very well.
Vehicle: WT sierra, GU CRD
Post Posted: Tue Apr 18, 2017 10:41 am
I may have missed it if you mentioned it... is this automatic or manual?
Maybe all rock steps look the same but a few in the pics looked familiar.
I love ZD30. :)
Post Posted: Wed Apr 19, 2017 7:13 am
One photo on the previous page is at Telstra hill, drove every track with highway pressures in the tyres. Well every track except for the big step but I don't think it is drivable any more.
All other top end photos are on private property, car is manual.
Post Posted: Wed Apr 19, 2017 10:19 am
That is impressive. I think the big step is doable maybe for a long car with some track building.
Will you be installing lockers or are you happy with the trac control?
I love ZD30. :)
Post Posted: Wed Apr 19, 2017 6:58 pm
The only way it will get lockers is if I stick dayna 60s under it and the only way it will get 60s is if I do a hemi swap. All very possible 8)
Especially as I am sure I have found a gold filled honey hole, just waiting on a new sluice to turn up so I can recover the gold
Post Posted: Sat Apr 22, 2017 7:20 pm
Had a awesome day cruising around Margeret diggings and Springhill goldfields.
Got a bit stuck in a little creek but the winch pulled it out easily
Drove up a dry creek for a few km and found a good spot to take my sluice.
Hopefully my new sluice will be here on Monday so we can give it a tryout on Tuesday.
Post Posted: Wed May 03, 2017 8:08 pm
Are the Dana 60s a bolt in affair, or is there more to it? Sounds like that smart fella Ball has a lot of work ahead of him. 8)
I love ZD30. :)
Post Posted: Sat Jul 29, 2017 7:38 pm
Turns out that it is pretty easy to upload photos to AZ.
Over the last couple of days I have fitted a snorkel, removed the crappiestly fitted UHF, made a good start
on a second battery and fitted a 46L auxiliary fuel tank.
Post Posted: Sun Jul 30, 2017 6:47 pm
I can see why arb wanted $2K to fit the tank, holy crap it was a mission.
Now has about 120L fuel capacity, suspension is next, have ordered 2" king springs and repco shocks. If I end up with 1-1.5" lift I will be stoked.
At the moment I only have 30mm between diff and bump stop so even stock height will be an improvement
Post Posted: Wed Aug 02, 2017 5:24 pm
New springs have turned up and as a bonus they are colour coded.
They were very cheap so will be interesting to see how they go.
Post Posted: Sat Aug 05, 2017 7:57 pm
Decided that I couldn't be bothered doing much today so went for a drive instead of fitting suspension
Post Posted: Thu Aug 17, 2017 6:57 pm
Suspension is in, haven't measured the difference yet but it doesn't look like to much lift.
Rides really nice which is a surprise seeing as I got all the bits from repco for about $400
Post Posted: Thu Aug 17, 2017 6:59 pm
Also I had to chuck the side step things away as they didn't like hitting the ground very much.
Sliders and flat flares are next
Post Posted: Mon Aug 21, 2017 6:56 am
Woohoo
Post Posted: Sun Sep 10, 2017 10:48 am
Easiest car to service especially after the last two Suzuki's I have owned. Takes longer for the oil to drain then to change the oil filter.
Getting it ready for a 12000km trip in 3 weeks. Still an awesome car.
Post Posted: Fri Sep 29, 2017 9:52 am
Just drove 2750km in 26 hours including a couple hours sleep at the SA/NT border.
Car is still awesome
Post Posted: Sun Oct 08, 2017 5:06 pm
So happy with the jeep that I am going to Darwin next weekend to buy a new grand Cherokee. :D
Post Posted: Sat Dec 09, 2017 7:48 pm
Car is going great. Now has 90000km on the odo so I have been driving it lots.
All I have done is bolt a table to the tailgate.
Post Posted: Sat Dec 09, 2017 7:50 pm
Woohoo
Post Posted: Tue Dec 12, 2017 4:39 pm
Haha
Post Posted: Fri Jan 19, 2018 10:54 am
Heading home from a fossicking trip in the north tanami and there really was gold at the end of the rainbow
Vehicle: G16b sierra
Post Posted: Thu Jan 25, 2018 11:00 am
Out of the two which one do you prefer? I know they aren't really comparable but which one is the favourite?
Post Posted: Thu Jan 25, 2018 7:17 pm
They are two very different cars but stick the 3.0 diesel and 8 speed in a wrangler and it would be my perfect car.
Post Posted: Thu Jan 25, 2018 7:18 pm
In the morning I am driving to darwin and if the road is open will come home via jabiru and taking the wrangler.
Post Posted: Fri Jan 26, 2018 2:40 pm
Yeah hopefully they realease it here. JL ute with a 3.0 diesel would surely be a big seller.
Post Posted: Fri Jan 26, 2018 6:41 pm
Every thing i have seen so far says we are only getting some crap 2.2L . 3L and turbo 2L is for usa only. Hope not
Post Posted: Fri Jan 26, 2018 7:20 pm
Yeah I don’t think we will get the 3.0 in a 2 door. The JT doesn’t interest me for the same reason cruiser Utes suck in the bush.
Users browsing this forum: No registered users and 6 guests
