It is currently Mon Sep 21, 2026 3:21 pm
Vehicle: 95 Sierra Soft top
Post Posted: Thu Aug 24, 2017 5:02 pm
Hey guys, it's been a few years since I last posted on here, it's been a few years since my Zook has ran to be honest ... Any who, I'm finishing my GTI conversion on it and just looking for ideas on what other people have to to mount there ECU
I know a lot of people mount there ECUs in the Glove box, up high and out of the way, but I still want to use my glove box, so I was thinking of putting the ECU in a waterproof box and mount it behind the glove box under the dash
What's everyone done ?
Vehicle: 1987 WT LWB Sierra Styleside
Post Posted: Thu Aug 24, 2017 5:26 pm
I remember hearing people say they've put it in the space above the glovebox inside the dashboard, but I could be wrong.
Post Posted: Thu Aug 24, 2017 6:48 pm
tupperware ...
or Decor
Post Posted: Thu Aug 24, 2017 8:40 pm
conformal coating... google it.
Vehicle: LWB Sierra
Post Posted: Fri Aug 25, 2017 11:56 am
I just used some heavy duty plastic soil bags, a few cable ties and some duct tape, works well
Post Posted: Fri Aug 25, 2017 12:18 pm
Top section on above the glove box sounds like a good idea, if your dash board is under water I think the computer would be last thing your worrying about lol But how would you get there ? Take glove box out yea ?
Conformal coating, I'll google it and have a sus, cheers
So place the ecu you in a water tight box and cut a hole out for the cable to run through yea
Post Posted: Fri Aug 25, 2017 12:53 pm
Conformal coating - fine, I guess.
Putting an ECU in a waterproof plastic box - No. Don't do this.
1) You won't ever seal it properly. It's not possible to cut a big enough hole in a relatively small plastic box to get all the plugs/loom through the box and then effectively seal it up again. A partially/poorly sealed box is worse than having the computer in free air because it will trap any water that does get in. The way to seal it would be to use a fairly stiff sided box or something like a Pelican case and then use a Cannon, Lemo or Amphenol pass though connector, which is going to be outrageously expensive. this would allow the box to be properly sealed but will involve masses of solder connections which add their own level of unreliability and potential impedance issues.
2) Computers run warm. This means they generate condensation when running if sealed into a box with atmospheric (i.e damp) air inside. Obviously, this also generates pressure and will try to defeat sealing, and when it cools it will draw in moist air from wherever the seal has been compromised leading to more condensation.
I have seen attempts at sealing computers, none of which were effective.
Some/many OEM's now run the computers in the engine bay or even on the engine itself, but, as you can imagine, they are built incredibly robustly and are generally fully potted with urethane to insulate and protect the circuitry.
The cars I have wired with factory ECU's up behind the dash (either above the glovebox or next to the steering column have never given trouble. Granted, I've never submerged a car to that depth and have no intention of doing so, but experience has taught me it is possible to clean and dry an ECU after submersion and have it work properly.
I do/have pressure washed the inside of my car with an unprotected ECU without issue.
Post Posted: Fri Aug 25, 2017 7:58 pm
Thanks steve ... food for thought, I had a little look see under the dash earlier today and found a nice spot behind the glove box on up high on the fire wall ... I don't have any intentions of submerging mine either but you never know what would happen lol hence my User Name "IN2DEP" lol
So box is not the best idea then, is there anything I can do to make it water resistant like spray it with WD40 or wrap the plugs up ?
Just for so added protection
Post Posted: Fri Aug 25, 2017 8:37 pm
conformal coating... seriously google it. Armsup
Post Posted: Fri Aug 25, 2017 8:48 pm
Just get a spare ecu and keep it in a tuppaware container, couldnt cost more than $50 off a wreck
Post Posted: Sat Aug 26, 2017 2:59 pm
GTIs are becoming harder to find lol
Atari4x4, who does this conformal coating ?
Post Posted: Sat Aug 26, 2017 3:19 pm
Ok I checked out this conformal coating on eBay, they do sell 2 types of it DCA and HPA ... not to sure which would be the right one to buy ? And what's the go with it, do I open up the ECU up and just coat everything in it with the stuff and that's it ?
Users browsing this forum: No registered users and 39 guests
