It is currently Mon Sep 21, 2026 4:47 pm
Vehicle: 1992 maruti mg410 lwb ute
Post Posted: Fri Sep 08, 2017 7:44 pm
Noticed my rear indicators, brake lights, reverse lights and Parker's stop working when I turn on the Parker's or headlights. All the front lights work and all the other rear lights work without the headlights or Parker's on. Checked continuity of grounds and checked all fuses. Only started doing it today. Not sure where to start with it tomorrow.
Post Posted: Fri Sep 08, 2017 9:58 pm
It's a ground issue, to be specific, it is a rear light ground issue.
Post Posted: Sat Sep 09, 2017 5:23 pm
Worked it out it was related to the chassi not being properly grounded to the battery and body.
Post Posted: Sun Sep 10, 2017 2:08 am
Ex factory, the chassis is not a part of the electrical system, the battery negative connects to the bell housing (for the starter & alternator returns) and to the body (for all other returns), so I suspect that at some point some one grounded your rear lights incorrectly, are discussing the vehicle in your avatar pic.? Was a tray conversion done?
Post Posted: Sun Sep 10, 2017 7:18 am
It has always been a tray back. Well Since Ateco imported it and chopped it into a tray back in '92. My accelerator cable snapped last week. I wonder if that was the path ground was taking to the chassis lol?
Post Posted: Sun Sep 10, 2017 7:25 am
I'm guessing on factory traybacks there was a cable to the chassi and it was part of the electrical system?
Vehicle: 91 Tin Top
Post Posted: Sun Sep 10, 2017 2:17 pm
Interesting, this is my factory wiring from the body to the chassis beside the drivers side tail lights. You can just see the connection onto the body in the background of this pic.
I was chasing a fuel gauge fault and found this wire had broken on the chassis side of the connection. I ran a dedicated earth for my fuel gauge and fixed this connection on the factory wiring as well.
And the passenger side also connects the lights to the chassis and the chassis to the body.
Post Posted: Sun Sep 10, 2017 3:23 pm
I believe only the earth on the LHS is factory. IIRC.
Post Posted: Sun Sep 10, 2017 3:43 pm
I ran some thick cable and ring terminals from the battery to the one of the bolts securing the fuel line on the chassis and it fixed it. My fuel gauge reads more accurately now too. I tested for continuity between the body and chassis and It was showing a lot of resistance before.
Post Posted: Sun Sep 10, 2017 5:46 pm
just went and filled it up and the fuel gauge actualy reads full now. Before completely filled up it showed just above half.
Users browsing this forum: No registered users and 66 guests
