It is currently Thu Oct 08, 2026 11:59 am
Post Posted: Sun Sep 27, 2009 3:20 pm
hey guy just wondering if any one has encountered this problem i went out wheeling last night and i was crawling in lowrange and it bounced and my car rolled back a bit and i noticed it wasnt in low range anymore and now since then doesnt stay locked into lowrange it just keeps popping out ???
im a bit worried about it and dont no what to do or were to start looking so all help on this would be great cheers
brodie
100 series cruiser 4 inch lift and 35s
1990 sierr
Post Posted: Sun Sep 27, 2009 3:22 pm
Id say its not the 6.5s doing this, its your lever.
Post Posted: Sun Sep 27, 2009 3:23 pm
my gear stick that goes into the tranny ??
1990 sierr
Post Posted: Sun Sep 27, 2009 3:25 pm
check your bush under the shifter is ok or replace.
check the stick is not hitting the hole in trans tunnel
check your transfer rubber mounts are still together and the arms are not bent.
its most likely one of the above.
mine will pop out sometimes if I scrub the transfer on a rock or something.
Post Posted: Sun Sep 27, 2009 3:30 pm
well i had a look under the car this mroning and it looked like the tranny case wass hitting on the rocks i was goin up but i have taken the top of the gear stick its not hitting the tunnel at all, the rubber mounts look alright so might be the bush under the gear leaver i have a little lookyat that today cheers for that fella's
brodie
1990 sierr
Post Posted: Sun Sep 27, 2009 3:45 pm
id say its your front output shaft of your transfer. im having the same issues now
Post Posted: Sun Sep 27, 2009 3:51 pm
have you found out why it is doin that ?? im a bit lost i installed the gears but never had a problem until now thats all.
cheers brodie
1990 sierr
Post Posted: Sun Sep 27, 2009 4:15 pm
i had a good look at the difference between the 2 zooks i have and the one that is playing up does have a slightly twisted tranny case arm mount so i will swap them over because the white one will be a trail rig so ill most probs end up getting a mighty kong or somehitng so aslong as my DD is alright it will be sweet ill try that see if that helps at all .
cheers brodie
1990 sierr
Post Posted: Sun Sep 27, 2009 4:18 pm
are you using the standard arms brobie?
if you are they are to weak stock for 6.5s.
you need to at least reinforce them
Post Posted: Sun Sep 27, 2009 4:25 pm
what do i need to look at doin then to make it stronger ?? i only run 31's atm i got 29 inch A/T's on it and this happened with the A/T last night when i went out ??
cheers brodie
1990 sierr
Post Posted: Sun Sep 27, 2009 4:39 pm
page 2
http://www.auszookers.com/index.php?nam ... pic&t=6596
Post Posted: Sun Sep 27, 2009 4:54 pm
cheers for that asjr illll do that on mine :) :) :)
1990 sierr
Post Posted: Sun Sep 27, 2009 7:10 pm
The side where there is two rubber mounts has 4 hidden bolts on the back of it, mine where working loose and mine kept kicking out of gear...
Vehicle: 1999 Jimny
Post Posted: Sun Sep 27, 2009 8:56 pm
Geez mate that sounds a bit personal........... :gross:
Post Posted: Sun Sep 27, 2009 9:14 pm
:lol: :lol: :lol:
Post Posted: Sun Sep 27, 2009 11:15 pm
Did you install the gears yourself? I presume you cleaned and re-installed the interlock balls and springs on the shift rails. Or have you done a twin-stick conversion that removes the interlock altogether? Sometimes a bit of crud can get in the springs and prevent the interlock ball from locking the shaft in place. When you shift the lever, does it "snick" into gear firmly, or is it more a case of move the lever to somewhere about the right place?
Post Posted: Mon Sep 28, 2009 8:18 pm
yes i installed the gears myself yeah i installed all that and its not twin sticks. i dont quite get what you mean by snick??
cheers brodie
1990 sierr
Post Posted: Tue Sep 29, 2009 3:11 am
cheers brodie
I meant when you move the lever, does it firmly locate in position, or does it slosh about vaguely? But from what you say, the interlock doesn't seem to be the issue.
Post Posted: Wed Sep 30, 2009 11:48 am
303zuke wrote:
cheers brodie
its allquite firm to move into any position but i think because the arm is slightly twisted its put the case more towards the frotn of the car and not allowing the lever to travel far enough to lock into 4L thats what im hoping im getting my spare one strenthen upa bit then ill stick it in and see how we go :)
cheer s brodie
1990 sierr
Users browsing this forum: No registered users and 87 guests
