It is currently Mon Sep 21, 2026 1:01 pm
Vehicle: Carless
Post Posted: Sat Feb 17, 2018 7:03 pm
This is possibly a tech question but ive just found the forum again after a good amount of months.
who carrys spares and where to stash them?
Was watching 4wd action today when they busted the 0 dollar zook's dif and got me thinking how hard it would be to find spares in the middle of no where so i guess thats what inspired me to make this thread.
Thanks for any awsners
Post Posted: Sat Feb 17, 2018 7:13 pm
The more you carry the more you need. The more modified your car is the more spares you need. It’s not hard and fast.
Post Posted: Sat Feb 17, 2018 7:58 pm
I found that carrying spare parts just made ya need them due to the extra weight.
If you are in the middle of nowhere then drive with a little mechanical simpathy. All I ever take is a spare tyre and the bits to change it
Couple of spark plugs, belts and hoses and left it at that.
Vehicle: Carless
Post Posted: Sat Feb 17, 2018 8:23 pm
thanks and i understand being nice to my car well thanks to my little laser i be nice to it and never be stupid unlike my brother when i give him the key's to it
Post Posted: Sat Feb 17, 2018 9:27 pm
The spares ive used over the years have been more a reflection of others pis poor prep and driving techniques rather than use on my own car for the most part.
Keeping ontop of your car mechanically and learning its boundaries sees fewer issues arise
Vehicle: suzuki sierra 91
Post Posted: Sat Feb 17, 2018 10:36 pm
I don't think you will ever carry enough spares to cover everthing
mate blew the heater radiator the other day in the middle of a 4wd trip nobody could have seen that coming and it completely stop him from driving had to leave his car there and take mine 1-2 hour drive back into town for parts
Post Posted: Sat Feb 17, 2018 10:48 pm
Only thing I really like to have with me is radiator hoses and some hose clamps. For everything else there’s fencing wire
Post Posted: Sat Feb 17, 2018 10:58 pm
Uni joints, transfer mounts, gearbox mount, engine oil, gear oil. Though we play hard and normally one of us will push past limits
Post Posted: Sun Feb 18, 2018 2:20 am
Are you talking about the heater core - bypass it with a length of hose and continue driving - I've got one vehicle where it's been bypassed for over a decade.
Vehicle: 91 Tin Top
Post Posted: Sun Feb 18, 2018 7:15 am
I’ve got a roll of this stuff in my tool bag, does all the bits that the small roll of fencing wire, roll of duct tape or bag of zippy ties can’t sort.... [emoji6]
http://www.rescuetape.com
Edit;
I also carry exactly Justcruisin’s list along with a set of front wheel bearings (just because I bought a front hub rebuild kit and haven’t fitted it yet) and a 10L Jerry can of water.
Online
Post Posted: Sun Feb 18, 2018 11:45 am
I carry
Radiator hoses
A length of fuel and heater hose. The fuel hose is looped around with both ends plugged into a spare fuel filter
Fan belt and timing belt. I normally wouldn't carry a spare timing belt but I had space for the old one so why not
Fuel pump
Dizzy + coil
Small box of relevant nuts, bolts and hose clamps
I did have a motorbike throttle cable repair kit in there but I used it on the LJ. https://www.ebay.com.au/itm/Universal-M ... SwilBZmlFl
+ the usual tape, cable ties, wire and steel epoxy
All that tucks in behind the trim panel that goes over the wheel arch on the passengers side rear. I also have a 10l water and 1l oil that live behind the passenger seat.
Most things you can fix up well enough to limp home. Eg for a broken transfer mount swap it with the compression side one and cable tie/wire the compression side in place. You can't really plan for breaking a diff and if you need to then you should really be upgrading that sort of component. Still, breaking a front diff doesn't stop you from driving a car. It depends where you are and what help you have but you can potentially drive out of that. With some work you can drive out with a toasted rear diff too.
Vehicle: Carless
Post Posted: Sun Feb 18, 2018 12:46 pm
Thanks everyone for the advice .
Guess i still over think everything and plan for things that might not ever happen :/
Post Posted: Sun Feb 18, 2018 1:08 pm
I made it 340kms from Mt Magnet back to Gero with a uni joint slapping around like a dick in a shirt sleeve :D surprised it made it that far, I was planning to remove the rear drive shaft and tonk home in front wheel drive!!
Anyhoo!! I like your fuel hose idea!!
Yep you can tape all those up for sure but hoses are light and pack in easy. If I were to have to travel long distances with limited water supply I’d prefer to replace the hose. But each to their own, and highly dependent on where you’re traveling etc.
Post Posted: Sun Feb 18, 2018 11:52 pm
THIS! - Whilst you cannot predict what will fail when - with a proper preventative maintenance routine, you should have an idea of what needs attention and you can inspect/replace before setting out on a long trip.
Post Posted: Mon Feb 19, 2018 8:00 am
Tbh, most failures I see are due to poor pre trip maintenance or poorly installed accessories.
In terms our outright parts failure, transfer case mounts and unis would be about it.
Post Posted: Tue Feb 20, 2018 8:14 pm
yeah that's what we end up doing but had to get some pipe that fit and a reducer because where it went in was a smaller pipe then where it came out
Vehicle: 85 Drover tin top
Post Posted: Wed Feb 28, 2018 5:22 am
I have got a spare clutch cable in the tool box
Post Posted: Wed Feb 28, 2018 7:59 am
Interesting that. I haven’t seen a Sierra clutch cable fail, but I have seen cars come out into the bush with faulty/slipping/jammed clutches which might lead to a cable failure.
Also I believe non-genuine cables are garbage.
Users browsing this forum: No registered users and 46 guests
