It is currently Wed Sep 02, 2026 6:15 am
Vehicle: 95 Vitara SE416
Post Posted: Wed Feb 21, 2018 4:39 am
Located at Sanctuary point 2540,3hrs south of Sydney.Jervis bay area.
Call for faster response 0437803397
Wrecking 96 jx vitara 4dr LWB
Too much rust to repair, so wrecking
vehicle:
Air con condenser 70
g16b distributor 80
g16b spark plug leads 25
g16b ecu (manual) has been serviced,can provide pics 60
g16b intake air box with MAP sensor 40
g16b clutch fan 50
g16b alternator 60
Shocks,standard height,good working order x 4 90
Bonnet latch 10
Bullbar to fit any lwb (4door) SE416 120
Rear diff centre 80
Passenger seat 50
Door cards x4 (tear repair passenger front)
Side view mirrors 50ea
Front drivers and passengers glass 50ea
Front manual window sliders 20ea
Whole rear door plus glass,missing trim piece 60
Bonnet 40
Tow bar with bolts 60
Headlights lhs 50 rhs has crack 30
Taillights 30ea or 50 for both
Manual shift knob and boot 30
Glovebox 20
Rear door seal 25
Rubber strips on roof 20ea
Inner door seals 10ea
Seatbelts 25ea
Window wipers 10ea
Manual pedals 50
Drag link bar 60
Windscreen washer bottle and pumps 20
Door handles,outer 15ea
Rola roof racks,complete 80
Ignition switch,3 door locks and fuel cap lock with new key 100
g16b sump 50
Diff shafts x2 1 long,1 short 50ea
Rear axle 40
All locking mechanisms for 5 doors
g16b vitara pistons and other engine block parts,as shown in pic
Vitara factory 2 piece spare wheel cover 25
15" circle rims x4 50
Most interior trim pieces available
Available mid march or earlier if wanted:
Complete g16b engine with a problem,keyway has moved throwing the timing out,needs repair, should be repairable, will know more when removed 200
OR
g16b engine wiring loom 50
g16b intake manifold and throttle body 120
g16b complete head,valves adjusted before removal 70
g16b block,recently had new rings and main bearings but has the problem above 50
g16b crank 50
g16b 16v valve stem seals - NEW
SOLD:
Engine
gearbox and transfer case
Front diff centre
Power steering
Wheels
Rear seat,cluster
Exhaust
Brake booster\mc
Radiator
Accelerator cable
Photos can be seen in my Gumtree ad:
https://www.gumtree.com.au/s-ad/sanctuary-point/wrecking/wrecking-1996-jx-suzuki-vitara-4-door-lwb/1174543947
Post Posted: Fri Feb 23, 2018 8:39 am
g16b engine parts added to Gumtree ad
Post Posted: Thu Aug 23, 2018 3:47 pm
do to you still have the indicator switch combo?
Users browsing this forum: No registered users and 9 guests
